Post Number: 208 Registered: 10-2006 Posted From: 66.90.229.240
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 30, 2008 - 1:07 pm: | |
The DD book has a long and complex procedure for "Storage of over 30 days", that few bother to follow. Someone suggested that Cat or Cummins had a preserving oil that whose vapors would rise and help the engine internals from slowly dieing? On aircraft there is a special storage oil , but at $50 a gal, with an 8v71 it would be expensive , even if totally reclaimed before use. On our boat 6-71 its a snap to pull every air box cover and spray fogging oil into each cylinder . On an 8V the task is much more daunting! FF |
Post Number: 268 Registered: 8-2006 Posted From: 74.33.61.72
Rating:  Votes: 1 (Vote!) | | Posted on Wednesday, January 30, 2008 - 3:05 pm: | |
Fred, on the 92 series it calls for mil-l-21260c 30w grade 2 preservative oil about 12 bucks a gallon fwiw |
Post Number: 210 Registered: 10-2006 Posted From: 66.90.229.11
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 31, 2008 - 1:24 pm: | |
Yes but, the Cat? folks have a far simpler solution with an evaporating penetrating oil. For folks that will be not using the coach for a couple of months , sealing the inlets and exhaust , and a quart or two of modern majic might at least get used. The DD required storage procedure is mostly ignored, and the results are e$pen$ive! FF |
