8v71 leaks help Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » April 2002 » 8v71 leaks help « Previous Next »
John Bessette (63.65.220.169)
Posted on Saturday, April 13, 2002 - 5:12 am:
Hi
The pan adapator on my 8v71 left hand 4106 is leaking on the left side or [lower side] i have tried every think at least 4 or 5 times. Has anyone got any good ideas what i can try next. about to weld it.
Thanks
John
4106 1926
AL (152.163.204.64)
Posted on Saturday, April 13, 2002 - 5:16 pm:
Jonh what all have you done to it to keep it from leaking? When you say lower side or left side, do you mean the end where the oil filler tube and dipstick are at? I had an oil leak problem at that place, and it was not the adaptor at all, it was the oil filler tube base. Another place you might want to look at is the oil filter adaptor.Check your oil level that it's 1 inch below the top of your oil pan. And also check for hair line cracks. If I can be of any help e-mail me. Good luck. AL
John Bessette (208.197.170.25)
Posted on Sunday, April 14, 2002 - 4:34 pm:
Al thanks for the come back
Yes leaks more so on that end where the oil filler tube is but it looks to be coming out all along the engine. I dont think it is leaking from the tube. I will check the 1 inch level.
I have changed the gasket 4 times using different glue like high tack,DD,cummings all good at least that is what the big boys say lol.
thanks again
John
4106 1926
Ted Calvert (Chowbus) (192.132.225.130)
Posted on Sunday, April 14, 2002 - 10:29 pm:
Don't know about the 8v, but oil leaks in general can be very hard to find. Your comment about it leaking all along the block-adapter joining makes me think it might be somewhere else, like maybe the breather tubes, and blowing along the block. I've had to Gunk my engine & trans, drive 3 miles, look for the leak, drive some more, check, very tedious.
Good luck.
Ted.
Phil (204.89.170.3)
Posted on Monday, April 15, 2002 - 2:05 pm:
There is an addative with florecent dye that can be put in the oil. You use a "black light" and the point of the leak stands out VERY well. Find a shop with the equipment, you will find the leak very quickly.
John Bessette (208.197.170.16)
Posted on Monday, April 15, 2002 - 4:50 pm:
Thanks to all
I got with DD in town and they have a black light but it is broke at the time but when they get it up and running we will try it. will let you all know what we find.
Again Thank
John
4106 1926
Phil Pellowski (Viater) (192.11.223.116)
Posted on Tuesday, April 16, 2002 - 5:15 pm:
John, you can buy a black-light bulb at someplace like "Spencer's Gifts" or any poster, head-shop etc. for a couple of bucks. Along with your basic 110V trouble light, a small inverter and an extension cord and you could be in business. Don't know where you would find the dye though.
It's just an option.
Good Luck!
Phil
4106-1726
