Bob Baldwin (Bob4106)
Registered Member Username: Bob4106
Post Number: 134 Registered: 10-2004 Posted From: 24.74.180.20
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 1:30 am: | |
What would be the normal operating temperature on a V730 allison automatic tranmission? |
Jim & Linda Callaghan (Jimc)
Registered Member Username: Jimc
Post Number: 41 Registered: 2-2004 Posted From: 66.175.206.159
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 4:04 am: | |
I don't know if mine is normal or not, but I usually run at 180-190 degrees Jim Wisconsin |
Larry & Lynne Dixon (Larry_d)
Post Number: 120 Registered: 7-2005 Posted From: 71.117.203.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 6:43 am: | |
Bob mine seems to run in relation to the engine. Thats when engine heats above 180 trany goes with it. I do know I watch and both are about together. 4905 Larry |
Post Number: 135 Registered: 10-2004 Posted From: 24.74.180.20
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 12:49 pm: | |
Thanks alot that will be helpful |
Post Number: 405 Registered: 1-2005 Posted From: 208.118.14.166
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 2:08 pm: | |
Mine runs at or slightly below water temp when on the highway - will go up 20-30 degress in stop and go traffic or waiting in traffic in gear (clutchs friction) |
Post Number: 406 Registered: 1-2005 Posted From: 208.118.14.14
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 19, 2007 - 6:52 pm: | |
OK - FROM THE ALLISON MANUAL FOR AT MT and HT transmissions SUMP FLUID 100 Degress F = Minimum 200 Degress F = Typical Continuous 250 Degress F = Max Converter Out Fluid Temp 300 Degrees f = Max |
Post Number: 136 Registered: 10-2004 Posted From: 24.74.180.20
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, October 20, 2007 - 3:11 pm: | |
Thanks Pete Very helpful |
