Joebus (Joebus)
Registered Member Username: Joebus
Post Number: 22 Registered: 1-2001 Posted From: 74.13.48.158
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 1:40 am: | |
Could someone suggest a product I could use to clean and polish my Alco wheels? I am not real good at any "high labor" process |
Post Number: 121 Registered: 5-2007 Posted From: 64.40.222.139
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 2:14 am: | |
HIre a couple of kids and work 'em. Just kidding. There are so many products that say very little labor required. I don't believe it. One product come to mind called Sheila Shine, never used it but it looks good. Some just buff the wheels and apply a wax coating like Turtle Wax. Even heard reports of guys at truck stops that will do the job. HTH, Paul |
Andy Wright (Wrightwy)
Registered Member Username: Wrightwy
Post Number: 20 Registered: 6-2007 Posted From: 70.193.92.94
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 2:35 am: | |
The labor thing is a issue with me as well, However to make them shiny you can either pay the piper or use a polishing wheel I have see the kits for about 50 bucks like te different size wheel and you supply the power I bought some polish froma truck stop in phoenix comes ain a bottle and is green it's called Zephyr PRO 40 good stuff but you still have to rub I have also use Eagle one Never Dull Comes in a can and you can buy at wal mart Thats all I know Good luck. Andy |
Bob Ayers (Califbob)
Registered Member Username: Califbob
Post Number: 39 Registered: 8-2006 Posted From: 4.246.93.2
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 4:46 am: | |
aLCOAHAS THIER STUFF.FORGOTTHE NAME CHECK THEIR WEB SITE. tHEY WERE GIVING IT AWAY AT A FMCA RALLY WORKS GOOD BUT STILL NEED TO RUB. |
Post Number: 47 Registered: 10-2006 Posted From: 76.223.90.238
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 10:35 am: | |
Here is a real time saving tip. Whatever type of polishing compound you use remove it with a dry washcloth containing dry flour. It removes the black way quicker than flipping a dry towel. I work out of a 1lb coffee can. You will be amazed. |
Joebus (Joebus)
Post Number: 23 Registered: 1-2001 Posted From: 74.13.48.158
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 1:53 pm: | |
Thanks for the info, I had them done at Richmond speedway this last weekend, but the drive back to Canada in the rain (they got dry before I could wipe them)means doing it again. Effort=results |
Austin Scott Davis (Zimtok)
Post Number: 170 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 11, 2007 - 2:00 pm: | |
I use the Eagle Aluminum Wheel Cleaner/Etching. I get it from AutoZone. One bottle is good for 2-3 cleanings on my 4104. Spray it on and rinse it off. DONE. . |
Jeffrey Smith (Greenhornet)
Registered Member Username: Greenhornet
Post Number: 64 Registered: 12-2006 Posted From: 198.136.32.74
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 14, 2007 - 1:19 am: | |
Her is a link to a longish article on the subject. Still a lot of sweat equity in the process, regardless. http://www.englishcustompolishing.com/usca/aluminum1.html |
Justin Griffith (Justin25taylor)
Registered Member Username: Justin25taylor
Post Number: 46 Registered: 4-2007 Posted From: 71.155.170.64
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 14, 2007 - 3:25 am: | |
Most of the "better" truck washes will do it pretty cheap. I can't remember exactly but I think $5-$8 per wheel. They clean/buff them then they seal them with some other product. Unless I am running in salt covered roads they stay shiny about 4-6 months. If you have to get a wash done at a Blue Beacon or "Blue streak" as we call them, don't let them "flash" the wheels or they will dull in a few days. I have never had any luck polishing them myself. On Eagles I usually have the bumpers done too. The XLII's and H3"s are usually painted. If anyone knows what the "mystery" product is they seal the wheels with I would like to know. I have asked but they won't tell me. I also have them done on my own Eagle and they last almost a year. But I only put 10-15k on my bus each year. Best, Justin |
