Tony & Kim Rian (Rianrts)
Registered Member Username: Rianrts
Post Number: 41 Registered: 1-2005 Posted From: 216.116.45.7
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 13, 2007 - 5:51 am: | |
Hi All my 1979 RTS doesn't charge we have had the bus for 3 yrs now. It has a 8v71 non-turbo with a rebuilt alt (the huge one that is gear driven) the last owner basically cut wires anywhere and everywhere. The stock regulater seems to be complete but most likely cut somewhere. Inside the batt box I have wires cut and hanging. Also this RTS has 24volt starter and a few 24v fans nothing else hooked up. I almost want to pull the 24v starter and go to a 12volt starter and change the fans out. I have an AMG for parts as well as a model for changing over to 12volt if needed. Shouldn't I just upgrade the reg and any thing else to the newer one and get rid of the old stuff in the batt box. For the last few years I have been able to run on my house batts for 12volt needs and watch how many times i have started the bus without recharging the 24 volt side. Thanks for the help!!! |
