Installing radius rod bushings Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » July 2007 » Installing radius rod bushings « Previous Next »
Henry 96A3 (Hank)
Username: Hank
Post Number: 106
Posted From: 69.129.126.133
Posted on Monday, July 09, 2007 - 11:25 pm:
I just got done installing new front radius rod bushings on my 96A3. They are the non sleeved variety. MCI has a tool you're supposed to use to install the bushings but I figured out an easy way that requires no special tools and thought I'd pass it along. Get a bottle of isopropyl alcohol (rubbing alcohol) and slather some on the OD of the bushing and the hole it seats into. Pound the bushing into place with a soft mallet. It works like a charm and the alcohol wont damage the rubber bushing. The alcohol will help you slide the rods onto the posts too.
Hank
