Steering knuckle question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » June 2007 » Steering knuckle question « Previous Next »
Henry 96A3 (Hank)
Username: Hank
Post Number: 96
Posted From: 69.129.126.133
Posted on Tuesday, June 12, 2007 - 11:47 pm:
I got the steering arm nuts off finally. The 125' breaker bar and several assistants did the trick. I'm thinking Godzilla musta torqued those puppies. Now the steering arm aint budging despite my best efforts with a sledge. Is it okay to heat the steering knuckle where the steering arm goes in? How the #$@& are you supposed to get that out? With a press?
Hank
larry currier (Larryc)
Username: Larryc
Post Number: 125
Posted From: 64.65.155.234
Posted on Wednesday, June 13, 2007 - 12:54 am:
Hank, Ya, get a big hammer! Really, place a pry bar between the draglink and the steering arm. Take the biggest hammer you have and while putting downward pressure on the draglink hit the edge of the hole to momentarily egg shape it. The tie rod end will fall right out.
Stephen Fessenden (Sffess)
Username: Sffess
Post Number: 700
Posted From: 67.142.130.26
Posted on Thursday, June 14, 2007 - 4:30 am:
A local shop here uses a portapower to take off those big rig pitman amrs etc. HFT has reasonbly priced ones.
Username: Larryc
Post Number: 128
Posted From: 64.12.116.203
Posted on Thursday, June 14, 2007 - 5:20 am:
Hank, its to bad you can't wait for a DOT Inspector to come by. I could almost guarantee it would at least be loose and probably fall off while he was just looking at it.
Username: John_mc9
Post Number: 372
Posted From: 66.217.108.75
Posted on Thursday, June 14, 2007 - 5:55 am:
Tie-rod ends, ball joints,etc.... Hold one big hammer
against one side, while you pound with another, on the
opposite side. The vibration will knock it loose in less
time than it took to read this.
Gotta' try it, to love it!
hammer ----->O<------hammer
Username: Chessie4905
Post Number: 587
Posted From: 71.58.117.21
Posted on Thursday, June 14, 2007 - 10:35 pm:
Oh, and make sure you are wearing some kind of eye protection. It does work.
Username: John_mc9
Post Number: 375
Posted From: 66.217.106.92
Posted on Friday, June 15, 2007 - 2:59 am:
Yeah! Ditto JohnW!
I got so much metal in my eyeballs, I can't reach for a cold beer
without the refrigerator magnets sticking to my head.
Username: George_mc6
Post Number: 192
Posted From: 76.168.69.233
Posted on Friday, June 15, 2007 - 4:45 am:
I like John's humor! Especially the one the other day about belts: Check the following, 1. There!
Having had the same problem as Hank, and done as much or more beating on the threaded end of the ball joint, as he has, with the same result, or lack thereof, I quit for the day. The next day, while beating on it some more, Leo came by and showed me Larry's method. ONE hit with a 5 lb sledge, and it dropped out. I'm STILL mad, and that was at least 5 years ago!
Good luck,
George
