Praying bus Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Praying bus « Previous Next »
doug yes (Dougg)
Username: Dougg
Post Number: 20
Posted From: 71.29.142.20
Posted on Wednesday, May 23, 2007 - 2:27 am:
Our 102DL3 has a kneeling system which looses air when the bus is off. So whenever we start the bus we have to listen to the kneeling buzzer, wait till the bus has air and push the return button to get it back up. We don't need the kneeler.Any suggestions to disable it?
Post Number: 1011
Posted From: 70.53.131.145
Posted on Wednesday, May 23, 2007 - 4:24 am:
Hello
You will probably have to fix the leak whether you keep the kneeler or not.
Why not keep it?
For safety sake, install another pressure switch in the side compartment that will interlock the parking brake with the kneeler buzzer.
When parked, no pressure in the line, no contact in the pressure switch, no buzzer. Release parking brake, and the system will be able to alarm as it does now, warning you it is knelt.
I loves a DL3....
