Syl Szucsko (Syl)
Registered Member Username: Syl
Post Number: 2 Registered: 6-2006 Posted From: 74.36.38.59
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 17, 2007 - 11:07 am: | |
Air is coming out the bottom of my R6 valve when I start to build up air pressure and also starts to bypass the push pull valve in the park position to exhaust. When push pull is in run position every thing is fine. The R6 valve is fairly new and I replaced the inversion valve also. Any ideas as to what is wrong |
Syl Szucsko (Syl)
Post Number: 3 Registered: 6-2006 Posted From: 74.36.38.59
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 17, 2007 - 12:45 pm: | |
OK found the problem bad service brake diaphragm |
Post Number: 327 Registered: 7-2006 Posted From: 66.217.105.86
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 17, 2007 - 11:01 pm: | |
Syl - Let me be the first to thank you for the update and cure! Some of us learn best through other's experiences! |
