Cutting foam rubber? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » May 2007 » Cutting foam rubber? « Previous Next »
Ed Jewett (Kristinsgrandpa)
Username: Kristinsgrandpa
Post Number: 311
Posted From: 64.24.212.240
Posted on Friday, May 04, 2007 - 7:46 pm:
I recently purchase a "Memory Foam" mattress and have been thinking about cutting it down a little in width. It is 4" thick and queen size.
I have successfuly cut thin pieces of foam by compressing it between two boards and cutting along the boards for a straight edge. Compressing it before cutting also makes a smooth side/edge, but is there any other way besides a hot wire?
I realize it's not going to be seen since it will have a sheet covering it, but I still want it to be a decent looking job.
TIA
Ed
Jim Stewart (H3jim)
Username: H3jim
Post Number: 286
Posted From: 68.6.175.166
Posted on Friday, May 04, 2007 - 7:59 pm:
Some foam can be cut very nicely with a turkey carver. Depends on how dense it is. The place where I buy foam uses a tool ilke a saber saw, but with a long straight, non serrated knife instead.
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 113
Posted From: 216.37.73.226
Posted on Friday, May 04, 2007 - 8:07 pm:
A factory I worked at used an upright band saw to cut foam. The "blade" didn't have teeth, instead it had a sharp edge like a knife.
Username: John_mc9
Post Number: 315
Posted From: 66.217.107.136
Posted on Friday, May 04, 2007 - 8:12 pm:
For foam rubber, styrofoam, etc... an electric carving knife is the way to go!
James Robinson (Jjrbus)
Username: Jjrbus
Post Number: 56
Posted From: 76.1.180.218
Posted on Friday, May 04, 2007 - 8:41 pm:
I've used the electric carvng knife on foam and on the sound deadening foam insulation, with good results. But never tried it on something 4 in thick.
Username: John_mc9
Post Number: 316
Posted on Friday, May 04, 2007 - 9:31 pm:
It'll cut through a 4" thick roast beef, as well!
Username: Chessie4905
Post Number: 538
Posted From: 71.58.117.21
Posted on Saturday, May 05, 2007 - 12:00 am:
Ummmmmm! BEEF!!
Randy Lackey (Leadfoot)
Username: Leadfoot
Post Number: 8
Posted From: 207.55.227.2
Posted on Saturday, May 05, 2007 - 12:12 am:
The turkey knife will work fine, but will be difficult on a long vertical cut. Just go slow. Any imperfections can be sanded out with 36 grit on a long block. We also use the bandsaw with 8 teeth per inch @ 150 feet per minute.
Username: John_mc9
Post Number: 317
Posted From: 66.217.107.198
Posted on Saturday, May 05, 2007 - 1:51 am:
How many teeth would that be, if he ran it for one hour and thirty-seven minutes?
Post Number: 541
Posted on Saturday, May 05, 2007 - 2:15 am:
You mean Randy or the band saw?
Username: John_mc9
Post Number: 318
Posted From: 66.217.108.114
Posted on Saturday, May 05, 2007 - 4:44 am:
HAR de HAR HAR!
