Engine jog to test and it started! Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » Engine jog to test and it started! « Previous Next »
Tom Mason (Manasst)
Username: Manasst
Post Number: 1
Posted From: 71.31.172.141
Posted on Monday, April 09, 2007 - 2:29 am:
i know Diesels are compression, no battery required, but i thought that you at least had to have some switch on. i had just installed new hydraulic fan pump and wanted to just jog the engine a few times. All start switches off. there is a start button in the rear that makes the engine turn over and a toggle to stop it when running. When i hit the start button, i didn't expect the darn thing to start. wasn't sure i had all belts on and hoses tightened. (more on that on another post.)
So my question is, why didn't it stop when i hit the toggle and disconnected power. it ran about 5 min while i tried all i knew of to stop it. i assume it ran out of fuel? what did happen?
obviously, i'm not a great mechanic.
clark lane (Bus05eagle)
Username: Bus05eagle
Post Number: 4
Posted From: 74.33.56.72
Posted on Monday, April 09, 2007 - 2:32 am:
Tom it had to build up the air pressure to shut down i found that out on my Eagle
David Hartley (Drdave)
Username: Drdave
Post Number: 755
Posted From: 72.189.203.211
Posted on Monday, April 09, 2007 - 3:02 am:
The fuel rack ( shutdown lever ) should be clamped closed (OFF) when working on the engine.
It is spring loaded and would fail (Open) without air pressure on the small chutdown cylinder.
These engines (mechanical) are designed to shut down using air pressure on the cylinder. No air pressure no shutdown.
You should locate the lever and paint it a bright color, make a small stick or block of wood that will push the lever closed and use it when working around the engine pulleys or underneath.
The rear start button is not a "JOG" button, It is a "START" button. Bumping a starter can be rough on the starter but worse on your physical wellbeing if you get tangled in the belts or fan.
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 21
Posted From: 70.110.2.160
Posted on Monday, April 09, 2007 - 3:21 am:
"You should locate the lever and paint it a bright color, make a small stick or block of wood that will push the lever closed and use it when working around the engine pulleys or underneath."
I love simple solutions. Nice safety tip Drdave.
Phil Dumpster (Phil_dumpster)
Username: Phil_dumpster
Post Number: 13
Posted From: 71.112.89.151
Posted on Monday, April 09, 2007 - 8:55 am:
The shutdown lever is located on the governor next to the throttle lever. You'll see a small air cylinder positioned in such a way to push the lever.
Chuck Lott (Chuckmc8)
Username: Chuckmc8
Post Number: 223
Posted From: 72.152.158.64
Posted on Monday, April 09, 2007 - 11:47 am:
-Info that all bus owners need to know-I keep a wooden paint paddle wedged in my rear doors to push the fuel off lever in case I need to shut the engine off b4 the air builds up. I also have a small peice of wood that fits between the air cylinder end and the fuwl lever so that I can block off the fuel, as others have suggesred. I just made a specific "too" for that job.
Lastly, dont reach in and push the stop lever with your thumb. I did that (without the big belt on) the little cylinder will extend and take out a corner of your thumb.......(looking at the scar now....) HTH
Gary Pasternak (Cessna5354)
Username: Cessna5354
Post Number: 14
Posted From: 152.163.100.13
Posted on Monday, April 09, 2007 - 12:27 pm:
Tom, do not underestimate your self as a mechanic, you are certainly smart enough to ask the correct questions, and really smart to ask the questions within this forum.
I feel bad that I take away much more info and experience from those who contribute.
This was shut down lever was the first thing a bus mechanic showed me when I got the coach. Now I will paint it, as suggested, as I KRS....
Thanks all,
Gary
Gary
Post Number: 120
Posted From: 4.240.213.65
Posted on Monday, April 09, 2007 - 3:43 pm:
Is this "problem" specific to DD or diesels in general (Cummins in my case)?
As I have read the board over the years, it amazes me how many things I don't seem experience. Maybe just fortunate...thus far. :-)
'64 Crown Supercoach (HWC)
Ed Jewett (Kristinsgrandpa)
Username: Kristinsgrandpa
Post Number: 304
Posted From: 64.24.209.147
Posted on Monday, April 09, 2007 - 4:43 pm:
There is no air shutoff on an electronic controlled DDEC engine, only a fuel shutoff, and that is controlled by the DDEC.
Somewhere on the coach there is a 12V breaker that provides power to the DDEC, if you have a DDEC controlled coach you should find and mark that breaker.
My only experience is with a DDEC II, so I am assuming that the other 3 in the series work the same, since they all have electronic injectors.
ED
