Crown alternator adjustment Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » February 2002 » Crown alternator adjustment « Previous Next »
jdexsquid (66.32.97.103)
Posted on Sunday, February 17, 2002 - 2:07 am:
OK, I need some help. I have a 1968 Crown Supercoach with the Cummins 220 Engine. My alternator is putting out 12.88 vdc. Is there an adjustment on the stock alternator to increase the voltage to 14vdc? Also, what does the stock unit put out in amps? Have any of you had one rebuilt, and if so what did it cost? Thanks in advance!
Jim
dougthebonifiedbusnut (24.218.115.126)
Posted on Tuesday, February 19, 2002 - 1:39 am:
hey idexsquid if you have the exturnal adjuster yes you can adjust it it looks like a small box with cooling fins on it about 3X5 just down stream of the alternator it has a allen head screw in the top middle of it with a + sighn on one side of the screw and a - sighn on the other just turn it as it sayes put a volt meter anywhere and adjust away only trouble is i think you would know that give me an email ill send you my #
