califbob (209.162.49.131)
Rating:  Votes: 2 (Vote!) | | Posted on Saturday, February 16, 2002 - 7:10 am: | |
This is a new one on me. The p/s fluid is blowing out of the resavoir on my orignal old style p/s. Any ideal of whats going on? |
Dwight (67.213.8.56)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, February 16, 2002 - 1:03 pm: | |
could be you have air in the system, jack up the front and turn slowly the steering wheel from right to left, do not hold or block the steering all the way to one end, check the fluid level and do it again.... |
John Rigby (64.12.107.21)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, February 16, 2002 - 1:35 pm: | |
If getting the air out does not work call Bill at Bab,s 1=888-783-1977.I had the same problem and they recomended new pump new 2.1 quart resavior with the new type filter and all the components to change it out.price was not bad. John Rigby |
Thomas Connolly (64.58.193.73)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, February 16, 2002 - 9:42 pm: | |
Mine did the same thing when I flushed out the lines and replaced the hoses, It took a bunch of Left and right turns to get all the air out and a while for the air foamed-up fluid to return to normal. Be sure that your full level is with the coach running. |
calif bob (209.162.49.212)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, February 17, 2002 - 5:23 am: | |
Thanks folks I'll try it. Bob |
Stephen Fessenden (Sffess) (63.25.125.15)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, February 20, 2002 - 2:29 am: | |
You say it is the reservoir, so it probably is. The pump has a simple overpressure relief that can blow also. Once blown, it needs a new relief thingamajig. |
Jerry (152.163.197.207)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, March 04, 2002 - 3:43 am: | |
One more idea for you -- I put a sheppard ps on my 06 -- used steering gear box, new pump, and used reseavoir. I had the same foaming problem for a while. Be it coincidence or what fixed / help fix mine but I removed the resavoir and tried to find anywhere air could be entering the suction side of the pump and compounding the problem. My resavoir has a filter in it and I noticed the bolt for keeping the lid on screws into the same shaft where the suction side of the pump is connected to. I simply put some teflon tape on the bolt holding down the lid and I was rid of the air a whole lot sooner and permanently. - Hope this helps. Jerry |
