Help Identify Mystery Part Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » January 2007 » Help Identify Mystery Part « Previous Next »
Chuck Brush (Chuckbrush)
Username: Chuckbrush
Post Number: 14
Posted From: 64.12.116.138
Posted on Tuesday, January 23, 2007 - 8:18 am:
I am trying to find the part that regulates the pressure for the air brake system. Is the horizontal cylinder shaped thing behind the air intake hose and just above the rocker cover it?
http://tinyurl.com/ypblj3
If not, then what does anyone suppose that thing is, and where might I look for the air pressure regulator?
Thanks,
Chuck
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 582
Posted From: 64.136.49.228
Posted on Tuesday, January 23, 2007 - 9:39 am:
it's called the D-2 air govenor...it's on the side of the air compressor,has two bolts holding it on, looks like a rocket ship.
Duane Bratvold (Connieandduane)
Username: Connieandduane
Post Number: 33
Posted From: 205.242.83.12
Posted on Tuesday, January 23, 2007 - 3:44 pm:
Hey Bob. Since I got the 4104 home I noticed oil driping out of the air throttle actuator. I talked to Father in law and he said he has changed the air compressor twice in the last year to try and stop it. Is there any other place oil could get in other than compressor seals?
Tim Hoskinson (Tdh37514151)
Username: Tdh37514151
Post Number: 204
Posted From: 4.224.234.184
Posted on Tuesday, January 23, 2007 - 4:00 pm:
Hi Duane if your bus has had a compressor push oil into the system it may take a while to get it all out as the air movement will push the oil through out the system. Make shure you have drained all air tanks and repeat draining them to remove as much oil as possible. Chuck as Bob mentioned most compressors have the air governor mounted right to the head of the compressor but not all some are remote mounted on the fire wall. These are found on older buses and trucks but are usually removed and replaced by the later compressor mounted style. You may also be looking at the system dryer look at the bottom to see if there is a drain valve
(Message edited by tdh37514151 on January 23, 2007)
Post Number: 16
Posted From: 152.163.100.138
Posted on Tuesday, January 23, 2007 - 6:07 pm:
I posted a photo of what I am looking at. Is this perhaps, the remote version of an air regulator?
Here is a link to my yahoo briefcase where the photo is: http://tinyurl.com/ypblj3
Thanks,
Chuck
Username: Rjlong
Post Number: 1170
Posted From: 71.195.127.101
Posted on Wednesday, January 24, 2007 - 12:54 am:
Chuck -
The link doesn't work. Tried it in both IE and Firefox.
If you resize it to less than 20KB, you can post it here.
FWIW & HTH. . .
Username: Sylverstone_pd4501864
Post Number: 255
Posted From: 216.173.223.253
Posted on Wednesday, January 24, 2007 - 2:14 am:
this is the pic he's talking about:
http://www.warbusaur.com/chuck/bypass.jpg
-dd
Username: Gusc
Post Number: 292
Posted From: 63.97.117.22
Posted on Wednesday, January 24, 2007 - 3:31 am:
Chuck,
From my memory I think your photo shows the water/air controller for the radiator shutters and contains some thermostats. Is definitely not the air gov because you can see it is in the water system.
The original air comp gov is high on the right side (Pass) mounted on the firewall and will have a small air line to the compressor. Or; it may have been converted to the new type mounted on the comp head. I changed mine on my 4104 to the new type but kept it on the firewall. Had to use a few different adapters for the air connections but figure it takes a lot less abuse and heat away from the comp.
Username: Gusc
Post Number: 293
Posted on Wednesday, January 24, 2007 - 3:33 am:
Chuck,
Forgot to mention, the new type looks nothing like either of the two original types. I, too, went crazy trying to find the one shown in the manual.
Post Number: 18
Posted on Wednesday, January 24, 2007 - 4:44 am:
Thanks Gus..... You have named the mystery part! Darn, I was hopeing it was the part I was looking for. At least I didn't have anyone pull it off for a rebuild.
Regards,
Chuck
Username: Gusc
Post Number: 296
Posted From: 63.97.117.17
Posted on Saturday, January 27, 2007 - 6:23 am:
Chuck,
Did you ever find the governor?
