Lift system Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » January 2002 » Lift system « Previous Next »
Devar (65.184.0.189)
Posted on Monday, January 21, 2002 - 3:16 am:
I have a 1969 Superior on a GM chasis with leaf spring suspension. When I tried to drive it up my new home's driveway, the rear scraped the road. I needed to put a railroad tie under the rear wheels to raise it enough to drive it up. Any suggestions for a system (air, hydraulic,or) to raise the rear about 6 inches at the wheels to get it up and down the driveway. It's really unpleasant to use this way!
Glenn (Paso) (209.178.166.11)
Posted on Monday, January 21, 2002 - 4:50 am:
If you have a power steering pump , maybe you
could use hydralic rams.
Peter Broadribb (Madbrit) (216.67.207.172)
Posted on Monday, January 21, 2002 - 5:58 am:
Have you tried backing in? It sometimes does make a difference.
Peter.
RJ Long (24.127.8.58)
Posted on Monday, January 21, 2002 - 6:48 am:
Another thought is to add some really large industrial caster wheels to the very rear edge of the chassis rails.
Seen frequently on FSSG rigs with long overhangs.
RJ
