Losing fuel prime Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » November 2006 » Losing fuel prime « Previous Next »
Tony & Kim Rian (Rian911)
Username: Rian911
Post Number: 5
Posted From: 68.118.58.211
Posted on Wednesday, November 29, 2006 - 3:40 am:
Everytime we go to start our 1989 eagle model 20 the fuel filters are half full and there is alot of air in the system. I was reading in the manuel that the model 20 came with a fuel pump in the system that of course was removed before we acquired the bus. This is a pain in the #&%. I know that most systems have a stopcock valve in the system but I can't find one in my system (did they not have one i.e. the fuel priming system in the back) Most of the time the batteries don't have enough of a charge to prime and then start the bus on one try?
Art Gill (Sandcastle)
Username: Sandcastle
Post Number: 17
Posted From: 208.11.184.64
Posted on Wednesday, November 29, 2006 - 4:03 am:
Is your a NJT Model 20? I have one with the priming fuel pump. But it has not worked since I have had the coach and I have not had any problem. I belive that it was only to be used when the filters were changed. If needed I can look at mine tomorrow and try to discribe how it is plumbed. But I don't think that is your problem. Let me know what I can do to help.
Art
Username: Lsilva
Post Number: 65
Posted From: 71.29.25.237
Posted on Wednesday, November 29, 2006 - 4:13 am:
While I'm not familiar with your particular bus, I think you may have a bad check valve (at the input to the primary filter) These can usually be dis-assembled and cleaned up.
Len
Post Number: 947
Posted From: 64.231.203.230
Posted on Friday, December 01, 2006 - 3:53 am:
On another post about removing air starters...
here's a long shot, are you an ex-NJT and was the fuel line that lubed the air starter properly terminated?
If not, source of air to fuel line and loss of prime.
