What is a 'Series 50' engine? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » December 2006 » What is a 'Series 50' engine? « Previous Next »
mark (Coolbus)
Username: Coolbus
Post Number: 30
Posted From: 71.1.128.196
Posted on Tuesday, November 28, 2006 - 2:47 am:
What is the difference with this engine from, say the DD two strokes I've seen?
Thanks
Mark
Jerry Campbell (Jerrync)
Username: Jerrync
Post Number: 39
Posted From: 76.182.44.149
Posted on Tuesday, November 28, 2006 - 3:33 am:
Mark the 50 series is a four cylinder version of the 60 series with 250 to 275 hp 890 tor @ 1200rmps that will get 10mpg the 6V92 has 257 to 277 hp with 816 tor @ 2100 rpm and will give 6 mpg
(Message edited by jerry@nc on November 27, 2006)
mark (Coolbus)
Username: Coolbus
Post Number: 31
Posted on Tuesday, November 28, 2006 - 5:53 am:
thanks Jerry
by the way, is this a two stroker?
thanks
MArk
Username: Dmd
Post Number: 116
Posted From: 71.125.9.251
Posted on Tuesday, November 28, 2006 - 12:27 pm:
4 stroke, usually a very desirable engine. It is on the heavy/large end of the scale.
Username: Kyle4501
Post Number: 245
Posted From: 65.23.106.193
Posted on Tuesday, November 28, 2006 - 2:28 pm:
very desireable = expensive
Another thing, since it is a LARGE displacement 4 cylinder, it cannot be dynamically balanced throughout the rpm range & it WILL shake EVERYTHING at idle. This shaking must not be that bad if it is still so expensive on the used market.
A inline 6 cylinder can be balanced & this makes for a much smoother power unit.
Now, If I could just figgure out a way to stuff a 12V71T in mine, that would be one smooth ride (even if it was thirsty :-) )
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 391
Posted From: 4.226.225.51
Posted on Tuesday, November 28, 2006 - 2:48 pm:
a little 6 cyl. cat will outperform a 12 cyl DD
Brian Elfert (Belfert)
Username: Belfert
Post Number: 22
Posted From: 132.148.80.215
Posted on Tuesday, November 28, 2006 - 3:37 pm:
Even a Series 60 in a bus designed for it vibrates a fair amount at idle. That is my experience with my Dina at least.
Brian Elfert
Post Number: 944
Posted From: 64.231.9.193
Posted on Tuesday, November 28, 2006 - 3:52 pm:
Hello.
Greyhound has some MC12 with the Series 50 installed, and there have been articles written years ago in the trade press of a number of fleets doing retrofits into MC9 for dedicated routes where the economy gains could be accurately measured.
I have driven one of the MC12 and they are nice. Mated to a an overdrive tranny, it is somewhat unnerving to be running 70 mph in that style of bus and not hear the engine screaming down the back. Extra torque is subtle, and of course, welcome!!
Fuel consumption only improves dramatically if you get the revs down with an overdrive or refrofit a taller differential gear.
See the coaches with Series 60 tied to a HT direct drive tranny, they don't get the economy that the overdrive B500 tranny will allow, unless a really tall diff is installed, and then start-up is harder.
The shaking is a problem, if you are going to be idling a lot. The high idle switch does smooth it out a bit in the transits where this motor is popularly used, and a busnut doesn't idle the way a commercial coach does.
Ricky D. West (Gg04)
Username: Gg04
Post Number: 1
Posted From: 74.241.196.238
Posted on Tuesday, November 28, 2006 - 4:04 pm:
Series 50 was originally a off road and export engine...DD engineers said it had to much uncontrolable vibration to be used in the domestic market...but smog, epa rules seems to have changed that opinion..first started popping up in transits after invention of reverser gear in transits to replace the 6L71ta ddec and Cummins being tried as fuel efficient smog engines..Then hound and everyone else started using as replacement to 92 series..about same physical size as a 6v92 a 3x3x3 foot cube..
Username: Kyle4501
Post Number: 246
Posted on Tuesday, November 28, 2006 - 9:38 pm:
RE: a little 6 cyl. cat will outperform a 12 cyl DD
Oh Yeah? I think it all depends on what you want for performance. I think a 12V71T would look way better than a simple straight 6!
3mpg won't matter if I never drive it! :-)
Mark Renner (Boomer)
Username: Boomer
Post Number: 5
Posted From: 12.180.53.193
Posted on Tuesday, November 28, 2006 - 9:42 pm:
I think the 50 Series is a very viable option, IF you are talking MCI. I know of two major fleets up here in the NW who have performed this conversion multiple times. And of course, Greyhound is running how many MC-12s with them. The beauty of putting one in an MCI is that virtually all the parts can be purchased over the counter, right out of the MC-12 parts manual. Complete Coach Works has also done a lot of these conversions. It's a nice little engine, and can achieve 325+ HP and 10+ MPG, but you will notice vibration at slow idle. Of course this is a DDEC engine, so matching up to a ATEC transmission, or better yet a WTEC, would be recommended. Consultation with an Allison rep who knows coach applications should be considered essential. The electronics involved in this application HAVE to be done correctly.
Post Number: 392
Posted From: 4.226.237.163
Posted on Tuesday, November 28, 2006 - 10:11 pm:
that's right, I forgot you never plan on driveing or finishing your bus :-)
Username: Chessie4905
Post Number: 350
Posted From: 71.58.126.56
Posted on Tuesday, November 28, 2006 - 11:16 pm:
Kyle: go with a 12V92; there are plenty of V-6's to put together to make one.
Username: Boomer
Post Number: 6
Posted on Tuesday, November 28, 2006 - 11:46 pm:
Why go halfway?? How about putting in a 16V92, or better yet, a 16V149!!! Seriously, 12V71's were a hecuva good engine. I had several back in my trucking days in the late '60s and '70s and I always got excellant service out of them, albeit hard on fuel. At 80,000 lbs. they all got a consistant 4.3, no matter who drove 'em or where in the western states they were running. They were a real long life engine. Never turbo'd one, but knew some guys that ran produce from L.A. to Edmonton that did.
RW Stoike (Rdub)
Username: Rdub
Post Number: 2
Posted From: 216.196.155.49
Posted on Tuesday, November 28, 2006 - 11:55 pm:
The Series 50 w/Allison 731 is a GREAT replacement for the 671s out there. I have this combo in my Silversides. The fast idle feature eliminates any vibration and a diesel should be "fast idled" anyway. Plus the cruise control and power steering pump add to the available options. Buy an RTS with a 50 and you'll have all the extra parts you need for the full package. Good Luck!
Username: Jerrync
Post Number: 41
Posted From: 69.132.150.103
Posted on Wednesday, November 29, 2006 - 12:01 am:
My dad is puting a 50 in his as we talk at will be at Arcadia this year. when I talked to him and sunday the 8v92 is out , so if any is looking for a 500 hp 8/92 in good shape and make sure that you had big fuel tanks. dad holds 400 gals Fuel=HP
Username: Kyle4501
Post Number: 247
Posted From: 65.4.181.89
Posted on Wednesday, November 29, 2006 - 12:20 am:
It's not that I don't plan on finishing my bus, I do, I just cant't decide which one of the 4 Scenicruisers I own to work on. :-)
However, If I could find a S-50 in a transit bus for the right price, I'd put her in one of mine as soon as I could!
I wouldn't have to worry too much about rust being shook off since it ain't a Eagle. :-)
Just kidding.
Username: Boomer
Post Number: 7
Posted on Wednesday, November 29, 2006 - 1:06 am:
Ouch! That's cold. At least an Eagle ain't sitting on the ground when the air runs out.
Username: Kyle4501
Post Number: 248
Posted on Wednesday, November 29, 2006 - 2:31 am:
Hey Greenwood,
Is a conversion ever finished?
My buddy that hauled my last 2 scenics home has a cat in his 2000 pete. he gets 5.1 mpg fully loaded at 80 to 90K lbs (heavy equipment) & it improves to 5.3 mpg empty. He's been keeping a fuel log for 440,000 miles to show it. So that 12V71 doesn't sound as bad. . .
As far as sitting on the ground when the air runs out, yeah, they do get real close to the dirt, but I was still able to crawl under the back to disconnect the park brakes, so it wasn't that low. But hey, I didn't have rust piles to crawl over :-) :-) :-) LOL
Seriously. I like Eagles, almost as much as the Scenicruisers. All aluminum construction can corrode too. At least with an Eagle I could weld it back. I still haven't learned how to weld aluminum. :-(
Dick Bell (Richardkan)
Username: Richardkan
Post Number: 39
Posted From: 152.163.100.138
Posted on Wednesday, November 29, 2006 - 2:39 am:
Sorry about the Ebay item reference Ian. But it seems to be somewhat on topic for this discussion. Personally had never heard of a 12v71 in this type of application #160056001872
Username: George_mc6
Post Number: 43
Posted From: 207.231.80.150
Posted on Wednesday, November 29, 2006 - 3:24 am:
Gosh, gotta get my two cents in!
All 100 MC-6s came with 12V71s and a Spicer 8844 4-speed stick. They burned clutches and broke transmissions at a high rate of speed. The crank pulley is actually IN the rear bumper, and everything is driven off a Spicer auxiliary drive in the right corner. In 1973 Greyhound converted 82 of them to an 8V71 with a 740 auto. 18 were left with the V12 for service in the Canadian Rockies. The V8's wouldn't get out of their own way, so the dog added turbo's which helped a little.
Mine was one of the 18, but the "buzzin dozen" is just too long to install an auto, so an 8V92 and a 748 are coming!
Post Number: 393
Posted From: 4.226.108.109
Posted on Wednesday, November 29, 2006 - 3:49 am:
I found something out that is hard to believe,at the flea mkts. ,they have those guys selling stuff to weld aluminum,they weld two aluminum cans together,that stuff is GREAT...
Username: Pete_rtsdaytona
Post Number: 286
Posted From: 72.40.3.47
Posted on Wednesday, November 29, 2006 - 4:58 am:
Boomer
Here's some interesting data - from a Study in Canada on diesel stationary engine - see appendix 1 - the Series 50 and the 6V92TA used almost identical amounts of fuel / hour
see--> http://www.ghgregistries.ca/registry/out/C1688-01DEC95-RPT.PDF
Pete RTS/Daytona
Username: Kyle4501
Post Number: 249
Posted on Wednesday, November 29, 2006 - 5:34 am:
As bad as my buses may be in your eyes, they still rate better than aluminum cans, well to me anyway :-)
I looked in to the flea-market alum welding magic several years ago. The only thing I remember from that was that it wasn't suitable for my needs, ie; not structural.
But since I suffer with CRS, it is possible I can't remember stuff. :-)
Username: Boomer
Post Number: 8
Posted on Wednesday, November 29, 2006 - 6:45 am:
Pete
That is a very interesting article. Industrial engines come about as close as you can get to operating in a perfect regime. Coach engines? That's another ball game. It would be interesting to get the real skinny on the difference in fuel MPG between the Greyhound 6V92 and S50 powered MC-12's. I believe that would be a true comparison. Anybody got connections at GHL?
Username: Ace
Post Number: 366
Posted From: 75.200.5.151
Posted on Wednesday, November 29, 2006 - 2:27 pm:
A little off topic but welding aluminum is not all that hard to do. It's more in the equiptment than it is in the equipment operator. If you have the RIGHT stuff, it CAN be fairly easy! A spool gun with a high frequency machine makes it even easier!
I personally like the tig method as it's a lot cleaner. Might be slower but I feel you have more control... again... FWIW
Ace
Username: Jerrync
Post Number: 42
Posted on Thursday, November 30, 2006 - 12:09 am:
Pete what I read that the 50 use 29.4% less fuel then the older engines
Post Number: 287
Posted From: 72.40.12.81
Posted on Thursday, November 30, 2006 - 2:58 am:
Jerry
what "older engines" - I still read 6V92TA is about the same as the Series 50
Please explain ??
Post Number: 44
Posted From: 206.149.192.43
Posted on Thursday, November 30, 2006 - 11:10 am:
The biggest operational difference is the 2 stroke gets poor mileage while operated under about 60% power.
The gearing and tranny spin the engine as if every mile were uphill.
The 4 strokes can operate at lower RPM efficiently and the electrics tell the overdrive tranny when to shift.
So one will highway "cruise" at 2000 RPM , the other at 1400.
Saves mucho fuel, part of the reasons ONE LASTS 300,000 MILES THE OTHER A 1,000,000.
Of course 60 extra years of engineering helps too.
John Harrelson (Jharl)
Username: Jharl
Post Number: 18
Posted From: 72.71.226.120
Posted on Friday, December 01, 2006 - 3:52 pm:
Hi all, I have a 8v71 in my 64 01 eagle, what would be a four cycle 400 hp relacement that would just about bolt in?
(Message edited by jharl on December 01, 2006)
Post Number: 399
Posted From: 4.226.108.83
Posted on Friday, December 01, 2006 - 4:12 pm:
3406 B CAT......don't forget the "B"
Username: Boomer
Post Number: 13
Posted on Saturday, December 02, 2006 - 7:55 pm:
No 4 stroke will "just about bolt in". It is a lot of work and $$. I put a ISM 450 and World trans in my M-10 and can attest to the above. In my modest opinion, the most HP increase for the $$ in your case would be to rebuild and turbo your existing 8V71. You can get 350 to 370 HP out of this, and the engine is pretty bullet proof. Next would be a 8V92 conversion. Special attention must be given to the cooling system in any case.
Post Number: 416
Posted From: 64.136.49.228
Posted on Saturday, December 02, 2006 - 8:32 pm:
the neat thing about a 3406 "B" is it's a non-electronic engine...no computer B.S. ..........( WEEEE )...& it will bolt up to a standard trans flywheel in a bus, so...get the engine straight & leval & make new motor mounts down to the cradel...
T. (Bluegrass)
Username: Bluegrass
Post Number: 220
Posted From: 72.160.128.210
Posted on Sunday, December 03, 2006 - 6:03 am:
Bob just wondering what are the dementions of the 3406 B and ant It the same as the C
Post Number: 420
Posted on Sunday, December 03, 2006 - 10:42 am:
'C' is an electronic engine...same physical size tho.... I just don't like the computer engines,the 'b' you just hook up a fuel line & battery & she is ready to go
Post Number: 46
Posted From: 207.231.81.154
Posted on Sunday, December 03, 2006 - 7:18 pm:
John, Mark is right, and the reason "T" asked for dimensions on the Cat was due to his concerns about overall length. The correct answer to your question about [a 400 hp replacement for an 8V71] "that will just about bolt in" is an 8V92T. It WILL bolt to your trans, give you lots more power, better fuel mileage, AND FIT IN YOUR ENGINE ROOM! NONE of the 6 cylinder in-line four strokes by Cat, Cummins, or a Series 60 Detroit, will fit in a bus which which was built for two rows of four, (V-8) without adding a LOT of cash!!! Any horsepower upgrade will burn more fuel, which will require more radiator to get rid of more heat. V71s, and V92s have two auxiliary drive connections on the back end of the cams, which turn at engine speed, one on the blower drive which turns at twice engine speed, and one on the side that can be made to turn at about 1.2 times engine speed. The bus builders usually used three of these to good advantage, and as there are none on the inlines, MAJOR modifications are necessary to the auxiliaries to to install a four stroke six. FWIW, & PsTP.
Post Number: 421
Posted on Monday, December 04, 2006 - 2:13 am:
don't want this to get into an arguement,but there is no need for a blower drive on a 6 cyl. cat & I don't know about the other buses,but my Eagle has 2.5 foot between the front of the engine & the rear door.
Username: Boomer
Post Number: 15
Posted on Monday, December 04, 2006 - 8:43 pm:
The fact that we are talking a Model 01 here makes a conversion slightly easier, in that the engine does not have to be set over to port in order for drive line alignment (05's and newer used the drop box) The Cummins M11/ISM engine family has the turbo and intake manifold both on the RH side of the engine (port side of the bus) which makes things slightly crowded on that side, what with air intake and charge air intakes both on that side. With a Model 01, the engine can be placed in the center of the engine bay. Nothing wrong with putting a Cat, Cummins, or Series 60 in as long as you are not on a financial budget. The Series 60 is taller vertically than the others, so the engine tunnel will have to be enlarged, AND the pan will be closer to the pavement. A coach oil pan will be a necessity, can't use a truck pan. When you start exploring the possibilities, carefully calculate the various measurements from your prospective engines, not just the overall dimensions, but the crankshaft center line, and driveshaft angle on your existing power pack. The driveshaft can only be shortened so much. Keep in mind that as Bob G. says, yes there is ample room to move the engine to the rear, but it affects the weight and balance of the coach. Moving that much weight back just a minor amount makes a large difference in how much weight comes off the front end. Before I did anything, I would carefully examine the bus frame for rust (this is a M-01 after all) to see if it will hold up to sinking that much money into it, or on it in this case. The cost of a new engine is just the starting point. Think of the cost of rebuilding and modifying your radiator to get the CAC pipes into the engine compartment, fabricating engine mounts, air intakes, exhaust, oil, fuel, electrical lines, fan drive, driveshaft modification, etc, etc. It ain't for the faint of heart, and this is why rebuilding/turboing your existing engine starts to become attractive. But, when you accomplish all this re-engineering, and spend all this money,you WILL have something to be very proud of. That's why we call ourselves busnuts.
Darren Upfield (Mwerx)
Username: Mwerx
Post Number: 30
Posted From: 66.82.9.55
Posted on Tuesday, December 05, 2006 - 12:12 am:
Hi all earlier this year I got talking to two detroit mechanics & the only good thing they could say about the 50 series was it would keep them in work till retirement, not one good word for it,yet I have not seen any bad words on the board ?? I know the uints they are working on are commercial use.any thaughts Darren.
Post Number: 47
Posted on Wednesday, December 06, 2006 - 9:16 pm:
Something got lost here! The blower drive on a V Detroit drives MOST everybody's alternator. The cam drives run the air comprssor and the steering pump on MOST busses. I know there is no blower drive on a turbo, what I was suggesting in the form of a question was, what do you do with ALL of the auxiliaries when you DON'T have drives? Putting anybodys inline 6 in a bus in place of a V-8 is going to require an additional foot of length... In an 01, how are you going to drive the mitre box? So, use an 8V92T, and the only large change will be the exhaust. A bigger radiator goes without saying.
