Air-assist Clutch for 4905 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » January 2007 » Air-assist Clutch for 4905 « Previous Next »
Glenn Williams (Glenn)
Username: Glenn
Post Number: 10
Posted From: 207.179.92.18
Posted on Thursday, December 07, 2006 - 3:32 am:
Been searching through the Board and can't find the thread about the air assist clutch on one of the GMC's. I think it was on a 4106 or 4107. The thread even had a picture of the air valve that is activated by pressure on the clutch pedal. I'd like to get part numbers for that valve assembly and info on how to install one in my 4905.
David Hartley (Drdave)
Username: Drdave
Post Number: 717
Posted From: 67.78.176.54
Posted on Thursday, December 07, 2006 - 3:43 am:
The air assist is usually a single unit and mounted in the linkage in the front drivers access panel under the floor. At least it was on my PD4501. The actuator and valve unit are all-in-one.
I know that probably isn't much help, But ( Kyle4501) may want to sell that actuator assembly if he doesn't need it on the scenicruiser #598
Dave....
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 434
Posted From: 64.136.49.228
Posted on Thursday, December 07, 2006 - 3:44 am:
seems like pete in florida had the parts off a RTS..... I might be wrong
Username: Glenn
Post Number: 11
Posted on Thursday, December 07, 2006 - 4:20 am:
Thanks guys! The unit I saw pictured must be very similar if not the same as the one's in the 'cruisers. I do remember that it is installed under the drivers area. Would it just take air from the tank that is in there as well, or off the supply side of the air horn?
Post Number: 54
Posted From: 4.235.206.249
Posted on Thursday, December 07, 2006 - 12:38 pm:
The 4106 used a "Mousetrap" a simple overcenter spring setup. Takes about 15 min to install, nothing to go wrong ,and reduces peadle pressure 80 or 90%.
Username: Glenn
Post Number: 12
Posted on Thursday, December 07, 2006 - 3:01 pm:
Fred
I'm not familiar with the "mousetrap". Is it something like an automotive dual spring throttle return? I am guessing it doesn't use any air, so nothing can go wrong? The pedal pressure on my 4905 is SIGNIFICANT! I'm a short person (5ft) so I don't get a lot of leverage on the clutch once it's down.photo
Post Number: 436
Posted on Thursday, December 07, 2006 - 3:17 pm:
Glen...
Look at a early Harley 74...my '59 had a mousetrap like he is talking about
Go to a Harley shop & tell them you want to see a mousetrap & how it works
I do believe it will take MUCH more than 15 minutes tho
Lots of times, it's the cable that goes from front to back,gets all hung on dirty ,coagulated grease inside the houseing
(Message edited by bob greenwood on December 07, 2006)
captain ron (Captain_ron)
Username: Captain_ron
Post Number: 646
Posted From: 66.174.79.229
Posted on Thursday, December 07, 2006 - 4:40 pm:
Unfortunately you probably won't find a mouse trap at todays Harley dealerships as that is an obsolete part. most of the young yeahoo's that work there would probably send you to Walmart for a mouse trap. I know from my own personal experience with Glens bus he needs help with that clutch, just wait till you drive it through Chicago traffic. Your next post will be for an automatic transmission :-)
Username: Rjlong
Post Number: 1127
Posted From: 67.181.163.170
Posted on Thursday, December 07, 2006 - 4:52 pm:
Bob -
GMCs do not use a cable for the clutch.
Glenn -
Here's a pic of the GMC Mousetrap, as installed on my 4106:
BNO Mousetrap
Yes, this moustrap would work on your 4905. Check with Luke at US Coach, JD at C&J or Dean's Coach for availability of a used one.
Also, be sure your clutch is adjusted properly. You'll need the shop manual, as the procedure calls for starting at the front of the bus and working your way back. When adjusted properly, the clutch can be as light as an old VW Beetle's.
FWIW & HTH,
Username: Glenn
Post Number: 13
Posted on Thursday, December 07, 2006 - 5:11 pm:
RJ - Could you e-mail me a bigger version of that photo? Glenn@threemenandatenor.com. Fortunatley, the good Captain included the manuals with the bus so I'll start with a full linkage adjustment. I like the mousetrap setup. Thanks!
Ron - Having just been throught Chicago twice in the last couple of weeks --OUCH! I'd need knee and hip replacement surgery!
Austin Davis (Zimtok)
Username: Zimtok
Post Number: 47
Posted From: 216.37.73.226
Posted on Thursday, December 07, 2006 - 5:32 pm:
I have a clutch air assist on my 4104 and it has a air cylinder mounted on the transmission that is connected directly to the clutch rods/throwout bearing fork.
I also think there is something mounted in the compartment under the driver.
Post Number: 437
Posted on Thursday, December 07, 2006 - 5:41 pm:
Glenn..
it's the same theory as a motorcycle kickstand,it has a spring & it breaks over center at one point
Username: Chessie4905
Post Number: 352
Posted From: 71.58.126.56
Posted on Thursday, December 07, 2006 - 11:26 pm:
My 4104 has the air assist clutch...everything mounts in the engine compartment. I beleive that HB industries sells one like mine, although expensive now a days. Mine has been on for about 20 years with never a problem.
Craig (Ceieio)
Username: Ceieio
Post Number: 279
Posted From: 207.101.213.58
Posted on Friday, December 08, 2006 - 10:07 pm:
Hi Glenn - sorry I am late to the party. This is a link to the HB Industries (HB == Honest Bob) air clutch. As mentioned, expensive, but perhaps worth it to you to get the most enjoyment out of your bus. I drove an eagle with an air assist clutch and that was very nice, no effort at all.
http://www.hbindustries.us/air.htm
Best of luck,
Craig - MC7 Oregon
Username: Dougthebonifiedbusnut
Post Number: 8
Posted From: 24.62.105.169
Posted on Sunday, December 10, 2006 - 11:21 pm:
Hey Guys
Need to know more about these "Mouse Traps" I'd love to put one on my Crown. Any info greatly appreciated.
Username: Gusc
Post Number: 244
Posted From: 63.97.117.33
Posted on Monday, December 11, 2006 - 4:41 am:
I would like to get my hands on a mousetrap for my 4104 also but they are hard to find.
HB's is great but it is $750 without installation!!
I rebuilt my 4104 clutch and shift linkages-forks, pins and bellcrank arms. They were all worn badly, some almost completely through. After the rebuild and very careful adjustment my clutch took about 40% of the effort as before. The whole idea of the adjustment is to get all the lever arms as close as possible to 90 degrees to the rods for max mechanical advantage.
Username: Rjlong
Post Number: 1128
Posted on Tuesday, December 12, 2006 - 5:14 am:
Glenn -
Check your private mailbox for pics.
Doug T -
No mousetraps available for Crowns, AFAIK. I've only seen them on V-drive GMCs.
Gus is right about making sure all the linkage is in top-notch condition and properly adjusted.
FWIW & HTH. . .
Username: Glenn
Post Number: 17
Posted on Tuesday, December 12, 2006 - 5:27 pm:
RJ-
Just checked the clutch arm on my 4905 and it does not have the attachement point for the spring on the mousetrap. Thanks!
Username: Gusc
Post Number: 245
Posted From: 63.97.117.14
Posted on Wednesday, December 13, 2006 - 7:15 am:
Glenn,
I remember seeing a stock mousetrap setup for a TD5103, or something like that, that had a wet clutch.
It should fit any 8V71 with a little improvising. I would put one on my 671 if I could find one. A 671 would take a lot more modifying but it would be worth it.
There are actually two air boost systems that I know of. The one by HB at the back and another one underneath the driver's floorboard.
Username: Pvcces
Post Number: 1028
Posted From: 65.74.69.234
Posted on Wednesday, January 03, 2007 - 4:29 am:
Gus, I seem to remember that there was a mousetrap that was built for a 4104 at Ted Campbell's Coach Maintenance in Williams, CA. I saw it when we were getting some work done in the middle of last month.
Google the business name.
Suncatcher
Ketchikan, Alaska
Username: Gusc
Post Number: 276
Posted From: 63.97.117.13
Posted on Thursday, January 04, 2007 - 6:00 am:
Tom,
Thanks, I just sent him an email.
