Ron Straub (Flightrisk)
Registered Member Username: Flightrisk
Post Number: 4 Registered: 10-2006 Posted From: 24.7.45.115
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 1:35 am: | |
The 4104 that I just purchased has this speedo on it's dash. Needs a new cable (at the transmission) but told that it works. Anybody with any information on this thing? I cant seem to find any. |
Tim Hoskinson (Tdh37514151)
Registered Member Username: Tdh37514151
Post Number: 187 Registered: 9-2004 Posted From: 4.253.120.229
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 2:21 am: | |
Hi Ron are you shure the speedo cable goes to the trans? You might want to look behind the drivers side front wheel at the spindle knuckle. Some 4104 buses had a front speedo drive that had a small shaft through the center of the spindel and drove from the bearing cap. My 1957 4104 has this option. Tim |
Post Number: 5 Registered: 10-2006 Posted From: 24.7.45.115
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 3:03 am: | |
I followed the cable from the speedo to the trans. The cable is broken at the transmission, but the housing is still attached. The cable is in several sections. It looks like I will need to have one made up. |
Post Number: 6 Registered: 10-2006 Posted From: 24.7.45.115
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 3:13 am: | |
OK, just found out I have a Kienzle Tachoghraph. It looks like an original. |
Frank Allen (Frank66)
Registered Member Username: Frank66
Post Number: 30 Registered: 10-2005 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 2:16 pm: | |
good time to get a electronic unit, that cable will cost and will probly give you a lot of trouble. they have them that can be operated off the left front wheel and they work very well, i have a dixon with a odometer on my 06 Frank Allen |
Bob greenwood (Bob_greenwood)
Post Number: 274 Registered: 7-2006 Posted From: 4.90.25.108
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 23, 2006 - 3:25 pm: | |
the cable can be brazed back together & gound down "IF" it's not in a bend |
Austin Davis (Zimtok)
Post Number: 30 Registered: 9-2006 Posted From: 63.94.78.194
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, October 26, 2006 - 8:39 pm: | |
Where can I source an electronic Speedometer? Someone had put one on my bus but the sensor at the wheel is damaged. The only "logo" is a "KK" on the face of the speedometer. . |
Post Number: 290 Registered: 7-2006 Posted From: 4.90.29.160
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, October 26, 2006 - 9:31 pm: | |
seems like 'jimcat had some senders...HEY JIM I think his address is : jimcat@webtv.net |
