Air lines ???? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » Air lines ???? « Previous Next »
Busfool (Chuck)
Username: Chuck
Post Number: 63
Posted From: 206.172.106.146
Posted on Monday, October 23, 2006 - 2:44 am:
I found some air lines on my mc9 that go out around the radiators into the air intake area for the rads but they are not attached to anything what are they there fore any one know? They are copper tubes they are attatched to lines over the back of the engine that are attached to two valve devices?
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 7
Posted From: 69.136.90.146
Posted on Monday, October 23, 2006 - 2:47 am:
air supply lines to shutters.
diesels do not like to run cold...less than op temp of 180 or so.....they carbon up which causes dramtically reduced engine life.
Busfool (Chuck)
Username: Chuck
Post Number: 64
Posted on Monday, October 23, 2006 - 2:59 am:
shutters where are the shutters there is nothing in front of the radiators Douglas did the previous owner maybe remove them?
Username: Tekebird
Post Number: 8
Posted on Monday, October 23, 2006 - 3:36 am:
probably although they are supposed to fail in the open position.
if they were failing closed they prob pulled them off if they were not a top rate operator
Austin Davis (Zimtok)
Username: Zimtok
Post Number: 27
Posted From: 63.94.78.194
Posted on Monday, October 23, 2006 - 1:44 pm:
I also have noticed a copper tube going to the top of the radiator and just hanging there. I looked in the manual I have for the bus and found that the shutter device is missing.
I would like to get this reinstalled if possible. Where do I get a replacement?
Username: Tekebird
Post Number: 9
Posted on Monday, October 23, 2006 - 3:14 pm:
Luke at US Coach in Berlin, NJ
Jay A. Geist (Trkynk)
Username: Trkynk
Post Number: 27
Posted From: 192.28.2.52
Posted on Monday, October 23, 2006 - 6:30 pm:
If it is the radiator shutters you need there is a brand new one on Ebay at $75.00. The ebay number is 180040105275. Good luck.
Username: Zimtok
Post Number: 29
Posted on Monday, October 23, 2006 - 6:56 pm:
I don't need the shutters, I am looking for the air device that operates them.
