4104 Speedometer Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » 4104 Speedometer « Previous Next »
Ron Straub (Flightrisk)
Username: Flightrisk
Post Number: 4
Posted From: 24.7.45.115
Posted on Monday, October 23, 2006 - 1:35 am:
The 4104 that I just purchased has this speedo on it's dash. Needs a new cable (at the transmission) but told that it works. Anybody with any information on this thing? I cant seem to find any.
image/bmpspeedometer
Tim Hoskinson (Tdh37514151)
Username: Tdh37514151
Post Number: 187
Posted From: 4.253.120.229
Posted on Monday, October 23, 2006 - 2:21 am:
Hi Ron are you shure the speedo cable goes to the trans? You might want to look behind the drivers side front wheel at the spindle knuckle. Some 4104 buses had a front speedo drive that had a small shaft through the center of the spindel and drove from the bearing cap. My 1957 4104 has this option. Tim
Post Number: 5
Posted on Monday, October 23, 2006 - 3:03 am:
I followed the cable from the speedo to the trans. The cable is broken at the transmission, but the housing is still attached. The cable is in several sections. It looks like I will need to have one made up.
Post Number: 6
Posted on Monday, October 23, 2006 - 3:13 am:
OK, just found out I have a Kienzle Tachoghraph. It looks like an original.
Frank Allen (Frank66)
Username: Frank66
Post Number: 30
Posted From: 207.200.116.13
Posted on Monday, October 23, 2006 - 2:16 pm:
good time to get a electronic unit, that cable will cost and will probly give you a lot of trouble. they have them that can be operated off the left front wheel and they work very well, i have a dixon with a odometer on my 06
Frank Allen
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 274
Posted From: 4.90.25.108
Posted on Monday, October 23, 2006 - 3:25 pm:
the cable can be brazed back together & gound down "IF" it's not in a bend
Austin Davis (Zimtok)
Username: Zimtok
Post Number: 30
Posted From: 63.94.78.194
Posted on Thursday, October 26, 2006 - 8:39 pm:
Where can I source an electronic Speedometer?
Someone had put one on my bus but the sensor at the wheel is damaged. The only "logo" is a "KK" on the face of the speedometer.
Post Number: 290
Posted From: 4.90.29.160
Posted on Thursday, October 26, 2006 - 9:31 pm:
seems like 'jimcat had some senders...HEY JIM
I think his address is : jimcat@webtv.net
