4905 question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » 4905 question « Previous Next »
Chris Smith (Catfish)
Username: Catfish
Post Number: 1
Posted From: 4.152.252.7
Posted on Monday, October 16, 2006 - 3:25 am:
I am looking at a 1977 4905 w/h A 4spd manual and everything seems to be in fair shape (it's going to need a few relays replaced but it has a bay full of NOS parts) But while following it down the road the other day I noticed it was tracking crooked anyway heres the question part I found a post in the archives saying somthing about replacing bushings may correct this problem.So how big a job would this be? What tools would be required?Any replys would be greatly appreaciated
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 47
Posted From: 209.50.74.6
Posted on Monday, October 16, 2006 - 3:50 am:
Chris
It is hard work. You have to crawl under the bus AFTER you put solid supports under the jack pads on the bus frame. Not enough room under the bus for you if the bags let go. Remove the radius rods which usually requires you to burn the rubber bushings off. Careful you don't set fire to it. Press new rubber bushings or they have a new hard material for them into the rods and reinstall. A lot of work but something we all have to do at sometime. Bill
Username: Rjlong
Post Number: 1048
Posted From: 67.181.163.170
Posted on Monday, October 16, 2006 - 3:57 am:
Chris -
What is the VIN on this 4905?
Username: Catfish
Post Number: 2
Posted on Monday, October 16, 2006 - 4:20 am:
oop's my bad He has two buses the 4905A is a 1976 #1472 the other is a 1979 H8H-649 #078 according to the wife)I am shooting for the 4905 because of the manual tranny
Post Number: 9
Posted From: 4.245.230.26
Posted on Monday, October 16, 2006 - 10:56 am:
"I am shooting for the 4905 because of the manual tranny."
GOOD THINKING!
Glenn Williams (Glenn)
Username: Glenn
Post Number: 4
Posted From: 207.179.92.194
Posted on Monday, October 16, 2006 - 4:32 pm:
I did replace the rear passenger side top frame end bushing on my 70' 4905A #44 (almost takes as long to type as repair!) The job took a couple of days. You'll need some stout wrenches/ 3/4 drive sockets and impact gun where you can get it in. I can't belive the diffenence it made. My bushing was entirely gone and it misalinged the rear bag on the passenger side and probably led to it's failure. Can't say enough about blocking up the bus securely! A piece of advice on that: a buddy of mine was a diesel mechanic for the Army. To make cribbing (blocking) they would use short sections of 2x4's staced into a log cabing style box. If it works for the Army, should work for us.
Username: Chessie4905
Post Number: 323
Posted From: 71.58.126.56
Posted on Monday, October 16, 2006 - 10:35 pm:
Since you don't have, at least the state you are from on your profile, I can advise to see Luke in New Jersey if you don't want to do this yourself and live nearby. He does lots of this work and makes it look easy compared to us doing it. If you have the tools to do this yourself, after getting it up in the air on suitable blocking, only do one rod at a time, as the suspension will shift some when you do one. Make sure you have some extra jacks, and one or two com-a-longs. Of course, big wrenches and some stout pry bars and a good air wrench. A porta-power would be nice, also if you had one. Also, get a shop manual for the coach, regardless.
Mike Eades (Mike4905)
Username: Mike4905
Post Number: 123
Posted From: 24.28.40.72
Posted on Tuesday, October 17, 2006 - 12:53 am:
Unless you have a real shop let the pro's do it for you. I had my front end done at jo-sam in Orlando, FL and had Luke at U.S. Coach in N.J. do the back end. He also checked the bulk head and I had to that to keep all inline. Heh Fred I like my 730. Mike
Username: Rjlong
Post Number: 1049
Posted on Tuesday, October 17, 2006 - 3:52 am:
Chris -
The H8H is a 4905 - GMC just changed the nomenclature in 1979.
Now, some historical data that might help you:
P8M4905A-1472 was delivered new in August of 1976 as fleet number 132 to Statesville Motor Coach Company, based in Statesville, NC.
H8H649-078 was delivered new in October of 1979 as fleet number 136 to the same company.
You mentioned that the '76 has a stick shift. Does the '79 have an automatic, or is it also a stick?
FWIW & HTH. . .
Username: Catfish
Post Number: 3
Posted From: 4.153.20.12
Posted on Saturday, October 21, 2006 - 2:24 am:
Yes the 79 is auto and according to the seller the motor and tranny where both rebuilt fairly recently so I believe I'll have another look at her tommorow
Stephen Fessenden (Sffess)
Username: Sffess
Post Number: 655
Posted From: 67.142.130.12
Posted on Saturday, October 21, 2006 - 2:43 am:
An H8H also has a shepherd integral type power steering, much better than the earler 4905 and 4905A assist type power steering. You will love the performance of the H8H with the 730 automatic. I had an H8H shell and a 4905A shell with manual. The manual is fun going forward but way way to fast in reverse for me. I think the H8H is the best GM ever built. I would love to have one but I am stuck with my Prevost.
Username: Sffess
Post Number: 656
Posted on Saturday, October 21, 2006 - 2:44 am:
If its the same seller, get the new coach with the supply of NOS parts from the other. You may be his only buyer and get everything you ask for.
Username: Rjlong
Post Number: 1058
Posted on Saturday, October 21, 2006 - 2:46 am:
All together now, let's all say "Awwwwww" for Stephen.
Poor guy's stuck with a Prevost. . .
ROFLMAO. . .
Hey Stephen - you going to Jack's Party?
Username: Catfish
Post Number: 4
Posted From: 4.152.252.121
Posted on Sunday, October 22, 2006 - 2:37 am:
We took the 79 for a test drive today about a 100 miles or so and went through all of the old girls service documents and decided too bring her on to the house. With the exception of having to replace one windshield a few electrical gremlins ( hi beams and horn)replaceing the rubber hinge on one bay door and a couple of airleaks she seems to be in pretty good shape.
I also came out of the deal with 2 brand new Deka batteries a couple of new side windows and a rebuilt tranny
