Rob Leight (Robleight)
Registered Member Username: Robleight
Post Number: 29 Registered: 5-2004 Posted From: 205.188.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 24, 2006 - 3:08 am: | |
Our Kabota Gen. is surging after about 2-3 hours of running. The generator itself sounds like the RPM's remain constant, but when I go inside the bus, the DC gauges are surging...along with all the lights, roof airs, etc. Since the problem is intermitent, it has been hard for Kubota to determine the problem. Any ideas?? |
Post Number: 113 Registered: 7-2006 Posted From: 66.217.107.61
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 24, 2006 - 4:26 am: | |
Re: "along with all the lights, roof airs, etc. " You sure you don't have a roof air that's going bad? A tough cycling AC unit can cause the genset to dip and dive.. and it'd probably be more apt to show, after running 3-4 hours... |
Bob Ayers (Califbob)
Registered Member Username: Califbob
Post Number: 13 Registered: 8-2006 Posted From: 4.246.229.143
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 24, 2006 - 5:05 am: | |
Rob My 8K was doing the same thing and it was the a/c regulator. They put on a new one made a couple of RPM adjustments and every thing is wonderfull. It was not the engine. |
Post Number: 30 Registered: 5-2004 Posted From: 205.188.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, September 25, 2006 - 5:33 am: | |
Yeah, I even turned off all the roof airs...same problem. Regulator...?? I am taking it in again this week to be looked at...will let you know. |
Post Number: 114 Registered: 7-2006 Posted From: 66.217.106.155
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, September 25, 2006 - 5:45 am: | |
My money's with Mr. Ayers, it sounds like a regulator problem. Please post the final findings and remedy to this same thread! Lotsa' luck! |
Mike Eades (Mike4905)
Post Number: 118 Registered: 12-2000 Posted From: 24.28.40.72
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 02, 2006 - 8:35 pm: | |
I had the same thing and I called Dick Wright at wirco. He said to change the voltage regulator. That worked. |
Post Number: 31 Registered: 5-2004 Posted From: 64.12.116.138
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 20, 2006 - 3:20 pm: | |
Hey guys, looks like it may be the regulator...good diagnosis. I finally had a guy agreee to come and look at it. He is a free-lance generator mechanic...used to own a Kubota place down South somewhere. He took one look and is coming back with a new regulator. $300, and we should be set. I'll keep you posted if it's something else. Thanks |
Post Number: 32 Registered: 5-2004 Posted From: 205.188.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 30, 2006 - 5:15 pm: | |
FYI - it was the regulator. Got it done this weekend, and it's running like a champ. |
Post Number: 327 Registered: 10-2004 Posted From: 75.201.249.171
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 30, 2006 - 5:37 pm: | |
Rob glad you got your generator straightened out but I have a off topic question for you. One you have a nice loking xl prevost and was wondering if you did the conversion or was it already done when you got it? I looked hard at one just like that, same color and all but chose the one I have now. Is there any way you can send me some inside pics of it? I could tell if it's the same bus from that! Again, if it is or isn't, it's a good looking coach! Ace |
Post Number: 328 Registered: 10-2004 Posted From: 75.201.249.171
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 30, 2006 - 5:41 pm: | |
No I looked up the old pictures of the coach we were looking at buying and it's different! Here's the one I was looking at! http://groups.msn.com/AceRossiMotorsports/motorcoaches.msnw?action=ShowPhoto&PhotoID=172 |
