Skip Sahler (Skip102dl)
Registered Member Username: Skip102dl
Post Number: 8 Registered: 12-2005 Posted From: 71.197.130.127
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 15, 2006 - 7:02 am: | |
Changed coolant in '94 102DL. Radiator sight glass is stained green from old coolant and new Texaco red doesn't show without climing up to get whithin a few inches to be able to see the level. I tried to wrench it out, but it seamed to want to stay put. Does anyone know if it screws out or is it normally soldered in? Now I'm hopping the new red will eventually desolve the old green stain. Thanks for any and all help! Skip |
Edwin C. Boso (Dred)
Registered Member Username: Dred
Post Number: 2 Registered: 8-2006 Posted From: 72.65.144.43
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 15, 2006 - 10:48 am: | |
If there is a large hex head around the sight glass then it screws out. Put a large socket wrench on it and have at it. Thanks, DrEd. |
Bob greenwood (Bob_greenwood)
Post Number: 143 Registered: 7-2006 Posted From: 4.227.116.38
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 15, 2006 - 12:42 pm: | |
I sure wouldn't want to be wrenching on that,sounds like an expensive mistake. whoever took care of my bus before me made a 'checker' out of a piece of coathanger,just long enough to reach into the neck & come out with one inch of 'wet' on it. it's an old coat hanger,with the paint sanded off & it has a very lite coat of rust on it,just enough to show 'wet' easily |
Ron Walker (Prevost82)
Post Number: 252 Registered: 11-2003 Posted From: 208.181.210.47
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 15, 2006 - 4:49 pm: | |
For what it's worth, Skip. A friend of mine has a fleet of trucks, running CAT C14's, and he was running red coolant in some of then. He lost 3 motors from cavitation. Went back to green and no more problems. |
doug Wotring
Unregistered guest Posted From: 69.136.90.146
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 15, 2006 - 5:26 pm: | |
Don't see how red coolant would cause cavitation. Cavitation is normally caused by a mechanical force ( water pump impeller, prop etc) Correct? CAT Coolant is Red, and Have used it in my 4104 for more than 10 years. |
Post Number: 148 Registered: 7-2006 Posted From: 4.227.115.241
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 16, 2006 - 12:48 pm: | |
I would be more inclined to say the person that put the red in, left a big air bubble in the cooling system,color does not do things like that |
Marc Bourget Unregistered guest Posted From: 64.142.42.176
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 16, 2006 - 6:38 pm: | |
Ron, Are you talking about cavitation or aeration? I'd "lean" towards the following distinctions. Coolant that has less capacity to raise the boiling point of the mixture would exhibit increased aeration. Coolant that, for example, omitted or reduced a surfectant would be more prone to display cavitation. |
