carl mci 9
Unregistered guest Posted From: 208.108.100.6
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 07, 2006 - 7:42 am: | |
I bought a 81 mci 9 in Boston Ma. When I was bringing it home to Ohio the engine dropped a bearing at the Ma\NY border on interstate 90. Does anyone know of a company in the area that I can get to tow my bus to ohio. Need to get it done fast. The company that towed it off the interstae is charging 40 dollars a day storage. thanks carl MCI9 This is about 50 miles from Albany NY |
JR Lynch (Njt5047)
Post Number: 50 Registered: 7-2006 Posted From: 69.132.238.127
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 07, 2006 - 11:25 pm: | |
In the meantime, perhaps someone living in the area could store the coach for you? If it's a 6V92T, there are a good many takeouts that could be bought and installed more reasonably than a rebuild...there is some risk with that approach...but a major engine rebuild could run into the $12 to $15K area too. Complete used 6V92T MUI engines are $2K and up. Maybe get some sort of oil pressure and run warranty? A used bus engine could be R&R'ed in an MC9 in a day easily. US Coach is down in New Jersey...856-767-4848 He would probably know who is in the area and who to avoid. If the tow down to Luke wasn't onerous, that may be a consideration...it would be a good move if doable. Hope someone is able to get you going! Sorry to hear of your misfortune...JR |
Post Number: 84 Registered: 7-2006 Posted From: 66.217.108.42
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 12:08 am: | |
I'd give Luke a call at that above number and see what he has to say.... The cost to tow that rig from Albany NY to anyplace in Ohio, is going to be more than the bus is worth. I'd wager that it'd be less expensive to have a local bus company (to where it now is) replace the bearing and get you rolling on your own. What kind of guarantee did you get with that thing? 30 days or 30 miles is typical.... |
Craig (Ceieio)
Registered Member Username: Ceieio
Post Number: 255 Registered: 12-2004 Posted From: 206.212.230.165
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 12:49 am: | |
You might try Nimco Bus in Newark for 6V92 takeouts. RH 6V92T lists at $4K on their site. 1-800-526-8055 http://www.nimcobus.com/ I have never used them, but I have seen a couple of favorable posts. |
Ed Jewett (Kristinsgrandpa)
Post Number: 261 Registered: 2-2003 Posted From: 64.24.209.171
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 12:34 pm: | |
Try these they were posted in Dec 03 and might not work. SHIPPING LINKS: www.FrankcoTrans.com (Highly Recommend! We use them often!) www.ShipVehicles.com www.DASAutoShippers.com www.PassportTransport.com www.AutoTrans-Express.com www.AutomotiveTransport.com www.IntercityLines.com www.HoreslessCarriage.com www.MoveCars.com ED |
Tim McWhorter (Theredwriter)
Registered Member Username: Theredwriter
Post Number: 42 Registered: 5-2006 Posted From: 70.5.114.133
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 2:18 pm: | |
Carl, If you choose to tow it down to Luke's place in South Jersey, I'll try to get a phone number for John Lilla. He has a wrecker service. We use him for all of our trucks if possible. Good, honest, fairly priced guy. I don't have his number with me at the moment. I'm in Northern Idaho. I've used him for over 10 years...he's very reliable. Let me know. Tim |
Sammy (Sammy)
Registered Member Username: Sammy
Post Number: 60 Registered: 8-2005 Posted From: 68.237.213.178
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 3:44 pm: | |
Try calling Adirondack Trailways in Albany. Maybe they can help,, or recommend a tow company they use in their area. 518-465-1491,1492 |
DMDave Unregistered guest Posted From: 71.125.9.62
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 08, 2006 - 7:54 am: | |
Those are good places to call. Also try Michaud Bus 1-877-MICHAUD BusesOnline.com Thats a big bus service corridor (lots of coach co's run thru there) Good luck |
Registered Member Username: Muziklvr
Post Number: 29 Registered: 7-2006 Posted From: 68.119.228.79
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 09, 2006 - 12:02 am: | |
carl,sorry to hear of your troubles.there is a LH 6v92 complete on ebay in the bus section(fully documented engine) with a current bid of less than $600. engine islocated in FL. guy says engine can be switched to a RH engine.suppose to have less than 60k miles.good luck to ya,and i hope everything works out. |
Post Number: 32 Registered: 7-2006 Posted From: 68.119.228.79
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 09, 2006 - 10:31 am: | |
carl, fellow busnut carl has a 6v92 with a allison 740 auto for sale for $2000. OBO.can hear run.contact him at 860-305-2080. this set up came out of a 81 mc9,and is located in conneticut. |
christopher
Unregistered guest Posted From: 24.147.59.101
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 09, 2006 - 6:58 pm: | |
carl peter pan bus in springfield mass can help you chris |
JR Lynch (Njt5047)
Post Number: 54 Registered: 7-2006 Posted From: 69.132.238.127
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 10, 2006 - 10:18 am: | |
NOOOOOOOOO....don't attempt to convert a LH rotation to a RH...not if you want to ride this year. Buy a RH. It could be converted, but changing rotation requires a ton of work...the cams, crank oil drilling, oil pump, oil jets...you get the picture. JR |
carl mci 9
Unregistered guest Posted From: 24.154.148.105
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 10, 2006 - 9:17 pm: | |
Thanks for all your help. I got a person from New York that is towing it to me in Ohio on Wednesday. This forum is the greatest and I only hope I can help someone as much as you have helped me. carl mci 9 |
JeffJJ Unregistered guest Posted From: 4.225.238.162
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, September 10, 2006 - 9:14 pm: | |
Greetings, Really, try to get your money back...you'll be money ahead. And, if it was purchased at a dealership, post the name of the outfit and the outcome of the negotiations. They must live or die on their reputation. |
