Mich Campbell
Unregistered guest Posted From: 206.172.191.129
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 01, 2006 - 8:47 pm: | |
Would any of you gentlemen/ladies have any idea how I can get this set up to work. I run a belt off the now removed AC pulley to a 12 volt 140amp alternator as per instructions from a post I got off this board some time ago. I cannot get it to start charging, any info would be great. Thanks in advance |
Bob greenwood (Bob_greenwood)
Post Number: 38 Registered: 7-2006 Posted From: 63.233.42.145
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 03, 2006 - 3:36 am: | |
I'd be glad to help,did you get a delco remey with the regulator built in it??do you have the cable hooked to your house batteries?? is it a 'one wire' alternator ? |
Registered Member Username: Cowlitzcoach
Post Number: 117 Registered: 4-2001 Posted From: 206.163.13.34
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 03, 2006 - 3:59 am: | |
Is it turning the correct direction? |
Post Number: 39 Registered: 7-2006 Posted From: 63.233.42.145
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 03, 2006 - 4:15 am: | |
it will charge either direction,it will cool better with it turning the correct direction |
Ross Carlisle (Rrc62)
Registered Member Username: Rrc62
Post Number: 135 Registered: 5-2005 Posted From: 67.33.46.218
The Bosch one-wire I installed will charge in either direction. Pretty sue that's true of any alternator. I think the only difference is the cooling fan. Some are internal, some are external and some are bi-directional....like the Bosch. The Bosch has a delay before it starts charging and it needs to see a certain RPM, although I don't know what that RPM is. If it's turning too slow, it will not turn on and start charging. May go without saying, but it also needs to be hooked to a battery. I actually know a guy that tried to connect an alternator output directly to a 12V buss bar with no battery....Then when it didn't work he took it back claiming it was bad. |
Post Number: 151 Registered: 11-2005 Posted From: 66.175.159.99
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, August 04, 2006 - 8:53 pm: | |
Ross is correct, those one wire alternators are a pain because of the high rpm exciter requirement. On a slow turning diesel you are far better off with a regular alt with a built in reg, very simple to install. If I were going to use one to charge house batteries only I would use one of the small GM ones from a car, they are cheap and reliable. There is a certain way to hook them up but it isn't difficult. (Message edited by gusc on August 04, 2006) |
