john david lebrun (Davidlebrun)
Registered Member Username: Davidlebrun
Post Number: 63 Registered: 5-2005 Posted From: 216.143.176.226
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 26, 2006 - 2:19 pm: | |
I'm putting the walls in for the shower, made out of 1/2 plywood, sandwiched with a 1inch space for the water lines. I'm thinking of caulking the seam and painting the wall, trying to protect it from water moisture. Any thoughts, |
Bob greenwood (Bob_greenwood)
Post Number: 4 Registered: 7-2006 Posted From: 65.150.44.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 26, 2006 - 4:18 pm: | |
I sure wouldn't do that...what if a water line broke or started leaking,I'd rather have the water line exposed. as far as sealing the plywood,go to your autozone & buy a couple of quarts of fiberglass resin,it will come with a tube of hardner,get some rubber gloves, get a tub to mix 1 cup at a time & paint the plywood with resin, rubber gloves & 1" paint brushes , (harbor Freight)36 brushes for 5 to 10 dollars....tub,at gro. store ,used to save leftovers,(kinda like tupperware) ;cept cheaper, 4 tubs for 4 dollars |
Post Number: 53 Registered: 7-2006 Posted From: 63.233.85.219
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 07, 2006 - 7:13 pm: | |
are you doing it? I will go into more detail if you want,also,would suggest NOT to use calking & use "PL CONSTRUCTION adheasive in the seams.--( home depo ) |
