mycol hudgens (Mycol)
Registered Member Username: Mycol
Post Number: 3 Registered: 7-2006 Posted From: 63.192.124.215
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, July 30, 2006 - 1:31 am: | |
Will a V-730 bolt right up in place of the VS2-8? Its in a 1975 am general transit the modle of the bus on the title is recon. Is there any mods that need to be done? Torque convertor? or Driveline. |
Bob greenwood (Bob_greenwood)
Post Number: 18 Registered: 7-2006 Posted From: 65.150.44.20
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, July 30, 2006 - 2:15 pm: | |
there is a possibility that the driveshaf will not be the correct length |
Jerry Liebler (Jerry_liebler)
Post Number: 224 Registered: 3-2005 Posted From: 71.31.3.88
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, July 30, 2006 - 3:23 pm: | |
The drive shaft is different and the V730 is quite a bit larger and may require bulkhead surgery too. You'll need to replace the flywheel with the flex plate that drives the V730. Regards Jerry 4107 1120 |
Dale Waller (Happycampersrus)
Registered Member Username: Happycampersrus
Post Number: 214 Registered: 7-2005 Posted From: 68.65.122.187
Rating:  Votes: 1 (Vote!) | | Posted on Sunday, July 30, 2006 - 9:05 pm: | |
Also the V730 is more heavy than the VS-8. It has to have a mount for the cradle. You would have to change the shifter also. I had to have the 2 1/2 spacer ring and longer dog bone. I had my drive shaft cut and had to change the flange to the tranny. The cooling & filter plumbing is different on a V730. Dale |
Post Number: 4 Registered: 7-2006 Posted From: 63.192.124.66
Rating:  Votes: 1 (Vote!) | | Posted on Monday, July 31, 2006 - 5:02 am: | |
Post Number: 5 Registered: 7-2006 Posted From: 63.192.124.66
Rating:  Votes: 1 (Vote!) | | Posted on Monday, July 31, 2006 - 6:59 am: | |
Does anyone know if I have to swap the diff? |
Post Number: 216 Registered: 7-2005 Posted From: 68.65.122.187
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, July 31, 2006 - 1:06 pm: | |
You shouldn't have to change the differential. Although mine is a Fishbowl I didn't have to change the differential. |
