guy johnson (Mcigeorge)
Posted From: 65.54.97.188
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 3:14 am: | |
Hi, I am the busnut's wife. Guess what my job is??? Yup cleaning. We are converting our bus slowly and as money allows. So we are "steel tenting". I have mopped the original floors like a dozen times in one day, and still the kids come out with black feet. Do you have any suggestions on how to get the floor clean? What can I use? We have taken half of the luggage racks out (the back part). I would like to hang something up over the windows for nightime and for times when we are getting changed, etc. Any ideas? I still want to be able to open and use all the windows. Thank you, The Wife aKa The Cleaning Woman Hubby said to tell you we have an MCI 9. |
John MC9 Posted From: 66.217.105.40
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 3:24 am: | |
Temporary shades for all the BIG windows? Hmmm.... Those grass mats that we use on the beach cost about a buck each. Each one is about 6' long and 36" wide. If you hang them long-way (across the windows), they fit fine, keep out the light, and offer great privacy for next to zip out of the checkbook. Just use wire attached to screws, threaded through the mat's edge.... Slide 'em open or closed as needed... |
Bob Greenwood Posted From: 63.233.41.91
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 5:12 am: | |
tie the kids up |
Jim Stewart (H3jim)
Posted From: 68.6.177.90
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 6:14 pm: | |
I'm not sure what kind of floor you have now, but if black is coming off, maybe some way to seal the floor. One idea might be to put some urethane over the top, the other would be to put down your new floor. That may be vinyl or whatever. Unless some other cleaner might work. Unless the black is transferring to kid feet from something other than the floor. Good luck and enjoy! |
Bob Greenwood Posted From: 63.233.5.37
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 8:08 pm: | |
might try waxing it |
Jack Gregg (Jackinkc)
Posted From: 72.129.232.62
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 8:12 pm: | |
Mini blinds at walmart are about $3 for 3 ft wide. The wider mini blinds might be less economical. Bungie the bottom so they don’t swing in route. Other options are stick to the window sill with heavy duty Velcro or keep them up while traveling. Cover the windows that you do not need with contact paper. Also, they can be partially covered with car wax or finger paint. Floor: try to find some used wall-to-wall carpet and cut it to size. Many portions of take-out carpet are nearly new. Jack |
Ron Crabtree (Ron_c)
Posted From: 70.56.28.139
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 8:28 pm: | |
There is Velcro that is sticky on both side you can use that for temp curtians, I used it on my door window just be carful when you pull the curtian off each time hold on to the side on the glass.It has been on mine for several years still works!Mrs. RMC |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 07, 2006 - 9:12 pm: | |
I have no idea if "BIG LOTS" is nationwide.I got my blinds from them,six foot wide for 7.50 |
Chuck Lott (Chuckmc8)
Posted From: 68.223.102.188
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 08, 2006 - 10:26 am: | |
Here's a possibility- for the floor, you can buy the green artificail truf outdoor rug at Home Depot or Lowes cheep in 8' wide width. Thats what your bus is. Get a piece to lay down in each section of the bus and roll it out when steel tenting and roll it up when working on the interior. When you are finished with it inside, roll it out for a patio on the drivers side on the ground. I keep a piece in my bay that we always roll out at campgrounds. It keeps a lot of mess out of the bus. For the curtains, I'd just buy some bed sheets and cut them to fit the windows and use push pins to hold them up on the wall. Fold them up and stick in a drawer when you dont need them. Hope this helps- Chuck Lott Douglasville GA. |
Registered Member Username: Mcigeorge
Post Number: 28 Registered: 6-2005 Posted From: 65.54.97.152
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 18, 2006 - 4:33 am: | |
Thanks for all the different ideas. I went and got some indoor outdoor carpet for inside the bus... and still working on the ideas for the windows. Thanks, The Nut's wife |
