Radius rod bolts stuck Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » June 2006 » Radius rod bolts stuck « Previous Next »
Glenn Williams (Glenn)
Posted on Monday, June 26, 2006 - 2:26 am:
I'm finally putting in the new raidus rod bushings in the pass. top rear end in my 4905 and I am having difficulty in getting the old bolts out. 2 go through the frame (one came out easy) and the other doesn't budge. No room for impact tools, just manpower with pipe over the wrench. Is there a trick? The stuck bolt is the forward most one. Additionally, one of the pin bolts has damaged threads and the other is missing it's nut. Are these bolts something I can buy from an industrial supply shop, or is there anything special about them that I should be aware of? I had planned to replace any damaged ones with grade 8 bolts.
