Battery compartment Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » Battery compartment « Previous Next »
Ron eagle 10
Posted on Tuesday, May 16, 2006 - 8:26 pm:
Do the gel type batteries have to be in a sealed compartment?
Posted on Wednesday, May 17, 2006 - 10:37 am:
NO , all batterys produce some heat while charging , which needs venting.
AGM are sensative to overcharging and usually require a modern adjustable charger , and the V regulator on the bus adjusted (turn a screw) to the proper charge voltage.
The hassles come if you MIX wet cell and AGM or some other combo.
