keith d dyson
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, April 15, 2006 - 2:03 pm: | |
hi there ,late on last year i posted a few threads to get our 60 series racetruck running right with all your help we managed to get the engine to pick up and rev correctly .we are now at the racetrack and although you can now press the accelerator and it picks up there is still no torque any ideas ? done the usual things fuel filters etc no codes on ddec reader . thanks in advance keith d dyson colletts racing team |
truthhunter@shaw.ca
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, April 15, 2006 - 2:24 pm: | |
Maybe it is embarrassed or just shy??? |
Brian Elfert
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, April 15, 2006 - 2:30 pm: | |
Are you getting any turbo boost? You may have blown one of the hoses to the charge air cooler. Brian Elfert |
keith d dyson
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, April 15, 2006 - 4:46 pm: | |
hi brian getting 30 to 45 lb of boost at the inlet manifold got all the right counts for throttle etc just no get up and go we used to have an auto gearbox but have manual one in now and all electronics removed from the allinson box running solely on ddec2 ecu any further ideas ? |
Sammy (Sammy)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, April 15, 2006 - 10:55 pm: | |
Keith, send me e-mail off line Sammy |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, April 16, 2006 - 5:34 am: | |
I despise secrets |
keith d dyson
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, April 16, 2006 - 6:49 am: | |
no secrets we have a detroit diesel 60 series ddec2 fitted in a erf es8 tractor 4x2 unit that we race in the uk ,just happened by chance to drop onto this website top dollar by the way .and through various peoples input we have turned round a poorly performing engine .our main problem was turbo lag as we use a shcwitzer sd400 turbo made to suit racing it takes some spinning but gives out around 35 to 60lb of boost depending on conditions any way ddec2 goes into fault after 25lb of boost if i remember correctly.any way to get round this we disconnected the turbo boost sensor and linked the throttle return signal into the turbo boost return .put your foot down and the ecu sees full throttle and full boost at the same time gives it loads of fuel and away we go .but we forgot that the ecu takes a snapshot of the external air pressure when the ignition is turned on so if you dont put your foot hard down when turning the ignition on it thinks its at the top of the himalayas and wont go as we want it to . we havent got our website up yet but brief details at www.btra.org team colletts |
tomnpat
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, April 16, 2006 - 7:44 am: | |
Don't know much, but a mechanic friend informed me that when computerized (hew) engines find a fault the set the engine to the 'limp home' mode. Little power, but we'll be home in a few days I guess. One of the engines he worked on needed to have the battery disconnected for a few minutes so when it 're-booted', it would load its normal program. Don't know if this helps. Let us know what you find eventually succeeds! TomNPat |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, April 16, 2006 - 3:44 pm: | |
Hello Keith. I'd be wondering if the missing auto tranny might be the gremlin. What signals does the DDEC get from the tranny that might inspire it to back off the power? Maybe it can't confirm a gear, so won't go to full power? Good luck, and let us know! happy coaching! buswarrior |
