Throtle Delay on 6v92ta Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » December 2001 » Throtle Delay on 6v92ta « Previous Next »
Skip Wood (204.134.99.94)
Posted on Wednesday, December 05, 2001 - 4:46 pm:
Has anyone had experience with a throtle delay on 6v92ta how do you adjust it when you set the rack or is it best to remove it if so how is there oil hole to plug thanks for any help
jim mci-9 (209.240.222.32)
Posted on Thursday, December 13, 2001 - 12:13 am:
you adjust the throttle delay after you have set the injector height.... depending of what injector/timing used determined throttle delay seting.... a gage is used to set it.... kind of a u-shaped feeler gage..... all the throttle delay does is retard the fuel timing until boost pressure from the blower comes up... its supposed to cut down on smoke on take-off or gear shifts...
