Left turn signal Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » April 2006 » Left turn signal « Previous Next »
dug
Posted on Tuesday, April 04, 2006 - 1:32 am:
My left turn signal does not work. Right turn signal works fine. Hazards work fine.
The flasher is not pulsing. Replaced the bulbs. No difference.
Any ideas?
Dug
75 MC8
Arcadia, FL
Dallas Farnworth (Dal300)
Posted on Tuesday, April 04, 2006 - 1:38 am:
Dug,
Have you got a two prong flasher or a three prong flasher?
If it's a three prong, the left side went tits up on you.
Dallas
Posted on Tuesday, April 04, 2006 - 2:05 am:
Check the continuity from the turn signal switch (at the lever)?
No meter? Just swap the leads and see if the left flashes with
the lever in the right turn position. Can swap the leads on the
three prong flasher, too... Trial by elimination.
dug
Posted on Tuesday, April 04, 2006 - 2:48 am:
Thanks guys.
It's in the switch. There is a small metal piece that pushes a red switch. The metal piece is bent. Must have happened when my kids were playing bus driver.
Dug
75 MC8
Arcadia, FL
