Electrical wiring help needed Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » March 2006 » Electrical wiring help needed « Previous Next »
Posted on Tuesday, March 14, 2006 - 9:04 pm:
I am installing a camera system, pyrometer, and tachometer in an 89' MCI 102A3. I do not have the manual for this bus. Can someone tell me the front and rear panel terminal numbers for the alternator "R" terminal, Back up lights, and any spare wires from front panel to rear panel. Thanks, Jack
C Fred
Posted on Tuesday, March 14, 2006 - 11:26 pm:
Jack I believe that the numbers are the same for all MCI, At least that is what I have found. check your Manual and see if they are . Fred
Chuck Lott (Chuckmc8)
Posted on Wednesday, March 15, 2006 - 1:41 am:
Jack,
I think this is what you need:
Front Junction Box
stud circuit # Color code gauge volt description
22 36C White 18 24 spare
29 63A Violet 14 - spare
41 815 Blue 16 12 B/Up Lamp
Ground return
41 815 blue 18 12 B/U telltale
43 56 green 16 spare
76 36B White 18 24 spare
81 R1 Red-Black 18 24 Tachometer
81 Tach White-black 18 24 Tach signal
from A
Rear Junction Box
5 815 white 16 12 B/U lamps
48 F1 yellow 12 24 regulator
51 60 yellow 18 24 spare
My book is 102D Series.
I can send the book if you need it-or send more info-
Hope this helps
Chuck
