Tony Richardson (206.133.65.161)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 15, 2001 - 5:54 pm: | |
I am changing an 04 from booster assist to a 492 sheppard. Can I change a spring in the stock pump and use it, or should I change it to a high pressure pump. Thank you Tony Richardson |
Jim Stacy (12.87.110.101)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, November 16, 2001 - 9:48 pm: | |
I was told if you have the small Vickers pump with the intregral reservoir it would not have the capacity for the Shepard box. I purchased the larger pump with a separate tank. Works great. I can get the model no's if you need them. Jim Stacy |
Frank Allen (24.214.104.60)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 22, 2001 - 5:00 pm: | |
You can change the releif valve and that will do it but you have to have the pump that has a remote resorvoir as the smaller one will not do the job Frank allen |
