Air leak Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » March 2006 » Air leak « Previous Next »
captain ron (Captain_ron)
Posted on Wednesday, February 22, 2006 - 4:03 pm:
My MCI 8 has an air leak in a valve? or some kind of contraption in the spare tire compartment. it only leaks when I release the emergency brake. so it's after the brake switch. the piece thats leaking has a round concaved face with about 5 holes in that area . since I don't have a manual I can't find what it is. air is coming out of those holes or posibly 3 holes that angle back towards the center. hope I'm being descriptive enough. is this part rebuildable or just replacable? and what is it's proper name?
dug
Posted on Wednesday, February 22, 2006 - 5:04 pm:
Sounds like a quick release valve. I had the same thing happen to me. Inside the valve, is a silicon gasket, bout the size of a 1/2 dollar. It is likely broken/cracked. I put electrical tape around mine to get her home.
Dug
75 MC8
Arcadia, Fl
rodney (Invaders)
Posted on Tuesday, March 21, 2006 - 5:10 am:
I have the same problem. I have a 1980 MC9 it has a bad leak right under the front of the bus where the spare is at we have seen and heard it but dont know what it is called.and i need to get some leveling valves for it but i need to fix the leak first i guess.to raise the passenger side of bus. should i fix leak first and what is name of the valve that im looking for? Thanks we have this bus because we have a gospel band and we travel around in it
