captain ron (Captain_ron)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 30, 2006 - 4:52 am: | |
no problems except for the marker and trailer lights started acting up again so I removed the last 2 marker bulbs on my trailer and that cured it. that fuse must be getting weaker. will fix that problem this week. I came from Murfreesboro,Tn. to sylva, NC. on 64/74 went up and down 6 to 8% grades with no problems. temp. gauge didn't barely move. I'll start putting in interior this week. and if old bus sells I'll get a lot done |
Bryce Gaston (Busted_knuckle)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 30, 2006 - 7:41 pm: | |
Way to go Ron, glad to see things are going well with yer "new" coach except fer the trailer lights, but sounds as if you got a plan there! Good luck and have fun with it! Bryce aka Busted Knuckle |
motorcoach1
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 30, 2006 - 8:45 pm: | |
ron i would concider putting LED lites on the trailer seems to have less current draw. just an idea. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 30, 2006 - 9:17 pm: | |
Ron I'd go ahead and change that "weak" breaker and then go with LED's on the trailer! If you are running 12V trailer system! Bryce aka Busted Knuckle |
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 30, 2006 - 9:53 pm: | |
Breakers do not normally get weak in the situation you have described. The connected load is just too high for the breaker rating. I also suggest you change all the trailer marker lights to LED'S to solve the problem. Richard |
