Scott Whitney (24.205.232.113)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, November 16, 2001 - 5:58 am: | |
According to Da Book (pgs 7-9) the model number will tell you. Of course that only tells you what it was when it left the factory. For example, if the number is: 7087-7X41 And the X is a '1', then it was originally a 2 valve head. If the X is a '2', then it was originally a four valve head. There is supposed to be a dataplate on the valve cover, although I could never find one on my engine. The model number & SN are stamped on the right rear side of the block, however, I could never find mine there either. . . BTW, it should be pretty easy to pull a valve cover off. That is what I finally did to find out I had a 4 valve. Scott |
