Steve Zona (Highwayrunner)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 04, 2006 - 9:24 pm: | |
Hi all. and Happy New Year. I aam in a tt campground in Menifee Ca. and a fellow bus nut,in the campground, with an 05 Eagle has a problem. in regular use his brakes and brakelights work fine. however when he has to use them hard, the brake lights won't go out. they stay on until he bleeds the line to the brake light switch. any ideas. come on guys, I assured him someone on this board would have the right answer. thanks in advance Steve and Cin 82 mc9 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, January 04, 2006 - 10:35 pm: | |
Get a new brake light switch. |
T. (Bluegrass)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 05, 2006 - 11:20 am: | |
I believe that i would start with a new brake light switch. Tony |
chris
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 05, 2006 - 7:17 pm: | |
upon release of the brake pedal all of the air pressure should bleed out of the line going to the switch. This must not be happening since bleeding the line turns the switch off. I would suspect the problem to be in the foot valve or one of the quick release valves. Chris |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 05, 2006 - 7:27 pm: | |
Chris - "in regular use his brakes and brakelights work fine. however when he has to use them hard, the brake lights won't go out. they stay on until he bleeds the line to the brake light switch. " |
james dean boggs (Jd_boggs)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, January 06, 2006 - 2:54 am: | |
Sounds like the quick release valve. If you want to replce the part, you can get parts at Colton Truck Supply. You are located just off the I215. Go north past the I10 get off at Inland Center Dr. Exit. Parts desk is 1-800-426-4644. Good Luck PS I pick up my bus just around the corner where you are. |
scott munrow
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, January 07, 2006 - 3:33 pm: | |
Try pulling up on the brake pedal. sounds crazy and simple but sometimes it sticks and needs some penetrating oil on hinge good luck |
dougthebonefiedbusnut
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 09, 2006 - 7:12 pm: | |
Scott is correct,happened to me.The brake lights would not go out. friend told me to pull up on the brake pedal. A little wd40 and the problem was solved |
