Need 102 parts and upper wall info Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » May 2005 » Need 102 parts and upper wall info « Previous Next »
Tim (Timkar)
Posted on Tuesday, May 17, 2005 - 2:40 am:
Does anyone have a source in western Canada for used baggage doors, fuel door, and battery door?
I am looking for either good take-offs or good condition fluted skins. According to the parts books the MC9 units will fit. Also need a RF rubber fender.
I have to replace the front section of the upper RH wall due to heat damage. I have read Dave Galeys book on using steel instead of aluminum and can get 16 gauge primed steel for about half the price of 11 gauge aluminum. I realize the front(steel) and rear(existing aluminum) pieces will have to be separated with a thin film of adhesive, but are there any disadvantages to using steel if it is primed and sealed properly?
Thanks for any and all input....
Tim (Timkar)
Posted on Tuesday, May 17, 2005 - 2:47 am:
Sorry, Should have mentioned this is a MCI 102A2
Jim Ashworth (Jimnh)
Posted on Tuesday, May 17, 2005 - 8:53 pm:
As to the aluminum, you should be using a tempered (T-6) sheet, .060 or .062 gauge. 11 gauge is not aluminum and if it were it would be about 1/8" thick. What you need is 1/16" thick.
Good luck with the project.
Jim
Tim (Timkar)
Posted on Wednesday, May 18, 2005 - 12:51 am:
Thanks for the response Jim. I just went out and measured the existing aluminum on the sidewall and it is .092 thick. I guess someone must have replaced it at some time in the past. I'll check out the price for material as you suggested.
