DAVID HEAD (Chuck)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, December 28, 2004 - 7:30 pm: | |
WHAT CAUSES THE ENGINE TO SMOKE WHEN I PULL AWAY FROM A STOP OR WHEN I REALLY POUND ON THE ACCELERATOR.THE CLOCK SAYS IT HAS 450000 MILES ON IT |
Geoff (Geoff)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, December 28, 2004 - 7:41 pm: | |
Overfueling. This can be controlled by your foot or by a throttle delay. |
John that newguy
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, December 28, 2004 - 7:44 pm: | |
Too much fuel getting dumped into the engine due to: 1. Larger injectors than are called for 2. Poor rack adjustment 3. A heavy right foot that's too used to automobile driving It's usually #3 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 29, 2004 - 5:13 am: | |
With 450,000 miles it could be low compression from shot rings , or rusted & pitted cylinder walls from too much sitting with out preservation. The COLOR if the smoke would help the diagnosis, also miles per gallon of lube oil. FAST FRED |
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 29, 2004 - 9:57 am: | |
If it was bad rings or bad cylinder walls, it would smoke all the time not just when pulling away from a stop sign. Richard |
TWO DOGS
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, December 29, 2004 - 10:19 am: | |
you are just giving it more fuel than it can burn...instead of instant acceleration...a diesel needs to be raised in r.p. m. more slowly...if you see a hill,start building your speed BEFORE you get to it |
