jack Watts (24.4.255.65)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 06, 2001 - 8:05 pm: | |
It's 90% outside and my eagle roof is bending and popping. I have just gutted it out and have taken the windows out. Is this normal for the roof to bow in some areas and sound off when it does? jack |
Prather (63.66.58.198)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 11, 2001 - 10:16 am: | |
If the structure is sound you should be able to remove everything, i.e. windows, siding, internal components without anything bending. So, somewhere you have a structural problem. Prather |
Karl crigger (152.163.204.83)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, September 04, 2001 - 9:47 pm: | |
Jack metal does that it is a lot easier for it toheat up with nothing around it dont worry a bout it it will quit when you insulate |
Steve 80 Crown Atomic (205.188.192.178)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 08, 2001 - 5:03 am: | |
Sounds a lot like different thermal expansion between the frame and roof panels. Does your bus roof have a steel frame and aluminum panels? If so, you might try painting the roof white to keep it cooler and lessen the expansion, or perhaps replace aluminum panels with steel. I don't think insulation will solve this problem. Steve |
Scott Whitney (63.151.68.130)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 09, 2001 - 12:17 am: | |
I've got aluminum roof on steel ribs. A coat of super reflective white (KoolSeal etc.) paint may do wonders. I now also have a 12 foot long roof rack that provides perpetual shade for 1/3 of my bus. Helps a lot too. Scott |
