Rob Leight (Robleight) (205.188.116.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 7:44 pm: | |
I have an '81 Eagle that just developed an air leak when the rear brake is applied. (I noticed it while sitting at a red light) If I don't hold down quite so hard (just barely enough to hold the coach still) no air is lost. I know there is something wrong like an air release gauge gone bad or something... Any suggestions? |
TWO DOGS (65.177.145.141)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 7:46 pm: | |
guess you can hear it ???....tell us where the air is leaking !! |
ralph7 (208.171.8.2)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 8:43 pm: | |
Air coach fully- use wheel chocks on both front and rear of 1 or 2 wheels -turn off engine- place brakes in driving mode (release emg brakes) - have someone apply brakes - and check for leaks- maybe a hose or a pancake or relay valve or But use care to be sure it does not roll. ralph7 |
joel garcia (24.27.103.155)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 8:45 pm: | |
i believe you have a bad brake chamber a certified mechanic will fix it all it is a bad diaphram i had the same problem on my 1978 eagle and i had it fix about four years ago hope this helps. |
TWO DOGS (65.177.144.229)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 9:03 pm: | |
hey JOEL...my serial number 19835 |
John Rigby (24.174.238.253)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 9:25 pm: | |
Rob, Does your air leak down on the gauge when you have your foot on the brake? It will leak when you first press the pedal. But does it still leak when you hold it? Not related, but I just had a problem with my 04 when I pushed the pedal it went all the way down. Luke thought it might be the diaframe of the pressure regulator valve.He was right. John |
Rob Leight (Robleight) (152.163.100.73)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 10:41 pm: | |
Yes, when I hold the brake pedal down, the air leaks out on the rear driver's side. I watch that air gauge drop and all of the sudden I'm out of air! |
Derek (Derek_L) (24.83.196.239)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 10:49 pm: | |
I'd say bad diaphram. |
TWO DOGS (65.177.145.188)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, September 09, 2004 - 10:50 pm: | |
yep ! |
Rob Leight (Robleight) (64.12.116.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 10, 2004 - 4:00 pm: | |
Hey guys, You were right. The diaphram was worn out and leaking air. I got it replaced for $5 parts / $65 labor. |
TWO DOGS (65.179.200.154)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 10, 2004 - 4:36 pm: | |
GOOD PRICE...keep them Eagles goin' TWO DOGS 1978 Eagle 05 sn 19835 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 10, 2004 - 5:06 pm: | |
Rob, Just for everyone else,for future you can buy the can, diaframe and everything for $22.00. also $3.50 for a new air line while your at it and replace everything. I have on both sides $51.00 total. John |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 10, 2004 - 5:42 pm: | |
John ... got part numbers ??? |
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, September 11, 2004 - 12:31 am: | |
will get them John |
