Bill (205.188.116.136)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 12, 2004 - 8:15 am: | |
I was wondering what kind of sealant do I use on the panel when I put it back together? There was so much different goop on it Iam not sure what the correct way is? Or is there a stock seal or gasket of some kind? Bill 4104-4032 |
Jim-Bob (12.46.52.74)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, August 12, 2004 - 2:12 pm: | |
Mine had an old, petrified gasket. I cleaned everything up & made a new one with 1/2" self adhesive foam weatherstrip. Biggest hassle I had was repairing all the "Rivnuts" which had gotten loose & spin where they are crimped into the sheet metal. Couldn't unscrew the hatch screws. I ended up glueing them with J-B Weld & they've been fine since. |
mclough (63.235.53.200)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 16, 2004 - 8:04 pm: | |
i used a silicone sealant and sheet metal screwed it back on. then went around edges with insulating foam. morgan www.outreachacrossamerica.com |
Jim-Bob (64.12.116.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 16, 2004 - 10:53 pm: | |
Well that's good, but what are you going to do NEXT time you need to work on something in there? Throttle cable, shift linkage, exhaust gaskets & mufflers....... |
