Frank Allen (64.12.116.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 10:38 am: | |
Have a 6.5 onan gen set, model 6.5 nhefr26100d, will strt righ up but stops when the starter switch is released, checked a sensor i beleve to be the oil pressure switch and found no problem, anybody got a wiring diagram or any information . Thanks for your time and expertise Frank Allen 4106 TX |
John the newguy (199.232.240.26)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 1:14 pm: | |
Might be of help: http://www.onan.com/onan/askOnan/askOnanTopicHome.jsp?marketId=41 -------------------------------------------------------------- Starting Problems My generator won't start. What should I check? Here are some of the most common causes we see for starting problems. The ones that apply for you will depend on the exact symptoms you're seeing: FAILS TO CRANK 1) Low battery. 2) Bad battery connection. 3) Blown fuse. CRANKS BUT WON'T START 1) Fuel below genset pickup level in tank. 2) Fuel supply shutoff valve closed. 3) Carbon deposits on spark plug. 4) Low oil level. RUNS THEN STOPS 1) Low on fuel. 2) Low oil level. 3) Excess oil. STOPS WHEN START BUTTON IS RELEASED 1) Low fluid levels--check and bring all fluids up to the appropriate level. 2) Possible overheating--check for blocked air flow or other possible causes of overheating. 3) Other functional problem--see an Onan-certified dealer for an accurate diagnosis. 4) No AC output--when the set is not producing power it will not continue running when the button is released. Unfortunately, there is a whole list of potential causes for this (from something as simple as a bad connection or dirty brushes on up to a bad control), so it's often difficult to diagnose without seeing a dealer for an accurate diagnosis. ---------------------------------------------------------------- |
TWO DOGS (63.156.216.29)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 1:21 pm: | |
I was VERY disapointed in "the dealer"...my electric choke doesn't work & they wanted to replace carb,intake manifold etc. hundreds of dollars,try driveing by a lawnmower shop & ask the guy to take a look at it |
John the cheapguy (199.232.240.26)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 3:16 pm: | |
Ditto Two Dog's reply. Disregard the "take it to a dealer" part and check what the manufacturer lists as "possible trouble". I had an estimate from a dealer for over $300, to repair the starter on our Onan 6.5. I bought the starter drive kit and did the job in 3/4 hour. Parts were about $30. I took the bride out for a special super-deluxe meal at MacDonald's with the savings. Was she ever grateful!!! (you gonna' finish those fries, honey?) |
Frank Allen (152.163.252.199)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 5:45 pm: | |
I know about the dealer, been through that, ill figure it out i guess and when i do ill put it on the board so everybody can benifit,thanks Frank Allen 4106 TX |
Pete RTS/Daytona (209.165.13.142)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 7:26 pm: | |
This one's for Two Dogs Found this Onan choke solution on The Classic GMC Motorhome B/B -- > http://www.surpluscenter.com/item.asp?UID=2004073118181640&item=11-2112&catname=electric for $3.99 you can fashion your own electric choke solenoid replacement Pete Rts/Daytona .____________ /_][][]/____/[]_| 1989 RTS-II T70206 6V92-TA DDEC-II V731 4.10/24.5 *--O-----------O-* Daytona FL.-Hard Beaches/Soft Women (386)672-0571 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 7:58 pm: | |
Frank This should help - The Classic GMC M/H (1973-1978) used a "works in a drawer" Onan 6KW model NH should be very similar The GMC M/H guys (I'm an x-GMC M/Her) have a great support network GMC M/H Onan Manual - On line http://www.bdub.net/manuals/onanmanual.pdf GMC M/H ONAN CONTROL BOARD OPERATION - On line http://www.gmcws.org/Tech/dsimmons/onan/onan.html GMC M/H Onan Control Board Diagnostic On-line http://www.bdub.net/OnanTestData.pdf .____________ /_][][]/____/[]_| 1989 RTS-II T70206 6V92-TA DDEC-II V731 4.10/24.5 *--O-----------O-* Daytona FL.-Hard Beaches/Soft Women (386)672-0571 Pete |
TWO DOGS (4.226.105.157)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 8:51 pm: | |
I tried to order that...it got so complicated,blood started running out of my ears... |
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 9:24 pm: | |
Two Dogs Sorry to hear about your near meltdown Just wait till Monday then give them a call - they also do bussiness the old fashion way - phone orders Pete RTS/Daytona |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, August 01, 2004 - 11:02 am: | |
Pete, thanks for the info ill look it over, the configureation of the engine is not exactly the same but the control should be simular Frank allen 4106 TX |
dwight (4.235.84.27)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 03, 2004 - 1:20 pm: | |
Hi Frank, if you have the same board as the NH power drawer, there are 2 relays on the board, the lower relay energises when the engine starts and it's alternator charges, once it closes, it energises the upper relay, Your probles could be onan 12 volt alternator not charging points dirty on lower points dirty on upper relay broked solder joint on board (you should be able to remove the relay covers to clean points) relay with covers removed, start the engine with outside start switch on the gen panel, once the engine starts, push on the lower relay contacts, if the engine continues to run, you may have a bad resistor on the board... you can watch the relays close and open. the top relay is double pole double throw the lower relay is single pole double throw the lower relay is the start relay and the upper relay is the run relay, (not a complete description but the just of it) Dwight |
