wclowes (142.173.53.118)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 30, 2004 - 11:56 pm: | |
I have a '79 mci 9 automatic that the back up lights stay on whenever the ignition is on.Can someone tell me where on the trans. the switch is located or what might the problem be? |
Marc Bourget (209.142.38.81)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 2:27 am: | |
I would guess that the reverse switch is stuck. I looked in my MCI-9 parts manual. 7F-8-214 is given as the part number, listed in the Misc electrical section but there is no key to a drawing. I looked in the transmission section and the only switch they list/show is the neutral safety switch. Looked in the body section to see if it's co-located with the shifter column and it doesn't show there either. Sorry I couldn't be of more help. Onward and Upward Marc Bourget |
DrEd (67.201.149.33)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 6:36 am: | |
I believe you will find the reverse switch for the backup lights located on the shifter mechanism in the cockpit. Thanks, DrED |
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 6:49 am: | |
If you have the Allison 740 automatic transmission, it may be a pressure switch in the reverse circuit on the transmision. I am at the fire station now, so I can't go look to see exact location of this switch. That is how our 73 MC-8 back-up lights were operated. I eliminated the OEM back-up lights (not bright enough). I cut 2 holes in the rear bumper and installed a pair of driving lights controlled by a toggle switch on the drivers side panel. This allows the light to be used for connecting in a campground, hitching toad or traile, as well as backing. |
BrianMCI96A3 (65.173.87.31)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 5:31 pm: | |
sound like a sticky switch where-ever it's located, but I couldn't find it in Da Books for my 96A3 either. Brian |
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 31, 2004 - 11:26 pm: | |
Thank you everyone for all the help. We are on the hunt! |
