RJ Long (67.181.211.253)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 03, 2004 - 2:52 pm: | |
MCIs are a "t-drive" layout, your 04 is a "v-drive, as you know. With a little yanquiengineering, you could probably adapt the MCI unit to your '04. IIRC, the unit is the same on the 5s, 7s, 8s, 9s, and A series, so finding one thu one of the bus boneyards should be fairly easy. Caylor Supply in KS, Dean's Coach in NC, Randy Fulkerson, or even Luke should be able to help. HB Industries in CA has a kit, too. HTH, RJ PD4106-2784 Fresno CA |
