4drifter (4.152.207.252)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, June 11, 2004 - 11:44 pm: | |
have a transfer switch has been out of service since 1999, when you put a load on it will run a few minuts and will kick out and back in. have checked the wiring with a meter and they checked ok.any sugestions? thanks |
bowlingshoegiverouter (63.185.65.69)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, June 12, 2004 - 12:53 am: | |
you need to explain it a little better,either the switch is bad ,or you are kicking it out because the two ends have a direct short...what kind of bus,where is this switch,whats it hooked up to,need more info |
4104 (4.152.207.149)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, June 12, 2004 - 7:16 am: | |
the switch transfer from shore power to generator is a automatic. it is just like you flip a switch off and on.does not do this with the battery charger on. the systems check out ok. the bus is a 4104 with two ac. |
bowlingshoegiverouter (63.185.80.167)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, June 12, 2004 - 10:32 am: | |
does it do it all the time (bad switch) or just when you run two air conditioners (overloaded) |
Jose (63.190.73.50)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, June 12, 2004 - 3:57 pm: | |
You may have rust on the Magnetic contact, A little sand paper will take it off, if You can get to it. Rust will keep it from latching in solid. Just a posibility! Jose, Just a dumb retired mechanic. |
