cgoodwin (208.12.29.127)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 12:47 pm: | |
I am in the process of converting a 6V92TA to burn recycled vegatable oil, a waste product of restaruants. The conversion is quite simple and involves the installation of a 50gal tank for diesel and conversion of the main tank to store and heat waste vegatable oil (WVO). The science: Diesels were originally designed to burn veg oil and even modern engines will burn WVO as long as it is heated to 170F (at this point the WVO's viscosity drops to 10 centistrokes, diesel fuel has a viscosity of 10 to 15 centistrokes)and burns cleanly and efficiently. Common issues: Coking: if the WVO is left in the injection system and burned as a fuel before it reaches 170F it can and will coke the injectors causing poor spray and the consiquent engine damage. Jelling: WVO becomes semi-solid below 40F, if left in the injection system below this temp, the WVO will clog the lines, injectors and pump. To avoid these issues two fuel tanks are used, the engine is started on Diesel and run to temp, the engine coolant heats the WVO and when 170F is reached a switch controlling an electric valve switches the fuel from diesel to WVO. 5 minutes before the engine is shut down it is switched back to diesel and run to purge the wvo from the fuel system. Advantages: WVO burns very clean reducing emissions by 60% Being made from plants which producted the oil by pulling carbon from the atmosphere, burning this product only puts into the atmosphere the same carbon which was used by the plant, and thereby does not contribute to green house gasses (unlike fossil fuels which pull carbon from deep within the earth and introduct it into the atmosphere) so you can hug a tree while driving. WVO is free, most restaurants pay $1.25 per gallon to have a company take it away and will be more than willing to let you have it. WVO is completely non-toxic and biodegradable. Simple, all you need to do is fill up at any McDonalds. Disadvantages: System must be installed. I have a VW diesel engine which has run WVO for about a year, I have taken it apart and all looks good. Many other engines have been converted including several GM units run as public transport, none have shown abnormal wear. Recommended reading: "From the fryer to the fuel tank" Tickell www.gresel.com www.greasecar.com Any comments???? Chris |
Peter Broadribb (Madbrit) (67.136.103.209)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 1:08 pm: | |
Chris, My own personal opinion is that unless you do a lot of miles, in otherwords you are on the road 50% of the time, I cannot see any real advantage considering the costs of the instal and the dangers and costs of breakdown due to coking, etc. Great for companies who have a fleet but not for an individual bus. Another thing to consider is whether one can get the oil as I have heard that a lot of major chain restaurants are not allowed to dispose of this oil in case the remover dumps it down the road or even causes a spill at the restaurant and the restaurant is liable for the clean-up. Also, a lot of them already have contracts for the removal. Like a lot of these great ideas, before long government will find a way to tax it and then it won't be cheap anymore. Peter. |
WVO wannabe (68.243.125.71)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 1:21 pm: | |
Chris considered doing the exact same thing.. The one problem I came up with was filtering. When I need to have a fillup is when I am on the road. If I am out an about traveling I would have to stop find a source with 100+ gals, then filter and fuel the bus. Sounds easy when you type it but a task when you would be actually doing it. I could take extra pre-filtered fuel with me. If taking pre-filtered how much? Depends on lenght of trip right? So I take the bays of the bus fill them with 55gal drums to transport fuel with me ready to go with pump to make fillup easier. Conversion is easy.. I would however if It was me instead of converting main-tank just add 2nd tank for WVO. This would allow the system to revert to normal usage with just removing the spare tank. Could a tank be built that would take up the entire 1st bay allowing maybe 400 gals of WVO to be carried? What about the extra weight of 400gals? How much does oil weigh? Oil appears more dense then water so maybe 10pds to a gal? What would adding 4000pds of extra weight to center of bus do? The biggest problem I see on the scale of use is the refueling when needed. I will convert a toad to use wvo where you can take 50gal with you with little problems. Just my thoughts.. |
Adame (129.82.229.195)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 2:38 pm: | |
It's becoming obvious to me that not only is this a good idea, it's in our national interest to find alternate ways to supply our thirst for fuel in this country. We are about 5% of the worlds population. We use about 30% of the resources. We create about 50% of the waste. The rest of the world sees this and gets pissed. One of the things I'd like to try is to pre-heat a smaller portion of the total supply of wv oil in order to be able to bring the system up to operating temperature quicker and also to cut down on the total amount of heat in the system. This might be done with a small insulated tank with a demand valve similar to a house type toilet tank. This would be a sealed tank with a failsafe overflow path back to the main wvo tank. What I'd really like to see is for the people of this country to lead the world in the areas of inovation and responsible use of this earths resources. I'd gladly pay tax on filtered wvo at the pump if that tax went to front a chain of alternative fueling stations. Bob |
Scott Whitney (69.35.62.177)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 2:39 pm: | |
Oil weighs less than water. SO your calcs are off a bit. I think one of the biggest hassles to this system is the filtering process. It takes a long time to filter all that WVO. To make a good system, I think you need a way to force filter the WVO in a reasonable amount of time. I.e. filtering the next batch the whole time you are driving down the road burning the previous batch. Not standing around in the MickyDees parking lot waiting for the WVO to filter thru. Travel in winter months makes the filtering that much slower. Also, in a DD two-stroke the injectors are cooled by the fuel and the excess is returned to the tank. So you would need to pre-heat the WVO so it can flow, but not so hot that it defeats the cooling of the injectors. Also, need to consider how the return flow of WVO will be re-routed so your switch-over valves really would be switching the supply and return lines. I certainly like the concept. I would love to run my bus on WVO. But I just don't have space (no bays) in my bus for the on-board processing equipment that I think you will need to make it practical and not just possible. Scott |
BrianMCI96A3 (198.81.26.45)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 2:43 pm: | |
WVO, actually oil is quite a bit LESS dense than water... If oil were more dense than water, huge oil spills on the ocean wouldn't get near the media attention... all the oil would fall to the ocean floor, a lot less newsworthy than an oil soaked duck. (grin) Brian |
TWO DOGS (63.185.81.241)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 3:03 pm: | |
I'm working on a nuclear powered bus... ....will be lots less trouble |
Mike M. (69.0.19.123)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 3:22 pm: | |
Except for the cooling issues..... and if you ever "throw a ROD" your bus will glow in the dark! |
TWO DOGS (65.179.200.150)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 4:43 pm: | |
my girlfriend says that already happens |
Henry R. Bergman, Jr. (Henryofcj) (209.210.116.241)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 7:04 pm: | |
Hate to say it, but the first paragraph in the heading "Advantages" is totally without logic. It does not matter where the stored carbon comes from...either from tiny vegetable forms layed down... ....millions of years ago as coal or oil, or from the carbon taken up from the plants today... ...that are "recycled" as vege oil, carbon in the atmosphere is carbon in the atmosphere. However, this aside, vege oil in diesels MAY hold promise. I would like to see the total... energy bill (and heat bill) using diesel vs vege. Western style farming is energy intensive. I bet the bottom line is cheaper energy wise to use diesel. This may change. Thank you. |
Jose (63.190.105.189)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 7:07 pm: | |
I believe I would check Your source in regard to restraunts " paying $1.25 a Gal. to have this oil hauled away " Actually this " Oil " is not really free. As a matter of fact this "Oil" is being sold to rendering companys by resturants. ( In some large chains it's actually figured in their profit & loss } I know this as a fact in the Mid-West & also Texas. { Texas find a guy $350 for helping himself to some of this " FREE OIL " } A lot of these tanks will have a padlock and the name of the owner. Most of this " Oil " is "cleaned" then sent to feed mills were it is mixed with livestock feed. It is a big enough industry that a co. in St. Louis is actually building tanks with heaters to place at restraunts to make pumping into tankers easier. When I was working we serviced a large fleet that hauled this "Oil", they used regular Diesel fuel in all their semi's ! I read a article about some guy's going to Mexico from the East Coast, I believe in a converted VW but could not find any " Free Oil " in the South-West. Remeber a Detroit uses it's Diesel Fuel to cool its injecters. There just ain't no Freebes left in this world ! Jose Just a dumb retired mechanic |
WVO wannabe (68.243.146.234)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 7:19 pm: | |
WVO it appears to be maybe heavier then actual oil. I dont know for sure that this is a correct statement.. I do know that oil floats on water but water seems to float on WVO. Maybe just a oddity. Seeing that the bus being considered has no bays I guess it is moot using one for storage. To make it work you still would have to carry enough WVO with you to use. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 7:34 pm: | |
Heating: I plan to use engine colant to heat the entire fuel tank as the oil runs better when warn and what the hell, it makes a great heat sink, then the oil will pass through a 1/2 ton refrigerant heat exchanger just before the pump. In practice this would be all you would need as long as the temp did not drop below 40F. Collecting: I have had no problem at all, every restauraunt manager I have spoken to has been very helpful and kind, I have even been given a free meal once! As for contracts Hmmmm, no one has said anything except one IHOP manager who told me that he would have to pay less to the disposal company and that would make his weekly profit go up and put him closer to his bonus. I planned a trip to Colorado this summer (I am in WA) and looked up restaurants along the path in a AAA road guide, I figured that Mexican food, fish and chip places and burger joints would have the most and I called several. I explained that I was driving a bus converted into a motorhome on a trip with my family, explained that the bus was a non-polluting experimental project which burned waste vegatable oil and asked if I could stop by on my way and "fuel up". Without exception every single place I called said they would be happy to give me all I could carry averageing 30 to 50 gallons, two said they had a 400 gallon tank I was welcome to. As for fear of spills... WVO is non-toxic and as far as I have found the EPA has no hazardous waste handeling sheet available for it or for salad dressing either. No one has said a thing about possible french fry liability. Filtering and tanks... Once heated the oil will pass through a Racor AF1000 filter which is a high volume diesel filter (.5 micron), in my system it first passes through a particle filter which pulls out any large bits, and the pick up tube which is inserted in the oil at the restauraunt, had a 40 micron screen in it. The tube is suspended in the oil tank and WVO is pumped via a transfer pump at 5 gal per minute through the filters and into the bus tank. Tanks: I plan to use the main tank (140gal) as the grease tank as it is larger, I will only be starting and shutting down the bus on Diesel so I figure a 50 gal tank will be fine, if one liked there is no reason that you could not fill the grease tank with diesel and if you wanted to reverse the conversion, simplu disconnect the coolant lines running through the copper coil installed in the fuel tank, remove the switch over valve and everything is as it was. Coking: As long as the engine does not burn grease at less than 170F, this is why you start on diesel, and all the WVO is purged from the pump and injectors prior to shutdown (run for 10 minutes on diesel before shutting down) there is no issue with coking. This conversion has been done a hundred times on farm equipment, semi trucks, urban busses, etc. The guy who owns www.greasel.com is converting his MCI! Return line: Use a 6 way solonoid valve and the return line is routed back to the pump inlet when on grease, otherwise the unused grease would be pumped back into the diesel tank or visaversa. All this is in the plan but a good point. As for cooling the injectors, when the engine is at temp the injectors are hotter than 170F simply because they are part of the engine, the preheated WVO is at the same temp as the coolant, which is less than the temp of the engine. Space: the whole transfer pump (to suck the grease up) filters and valves fit in a spacee slightly larger than a shoe box. If space is really the issue and there is no room in your plan for an other 50gal tank, the main tank could be devided. You would still have the same capacity but it would be split between the WVO and diesel side. BTW the WVO can be kept in a plastic marine tank and is as safe as transporting salad oil from the store to your home. Chris |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 8:45 pm: | |
Hi Chris, This is an interesting thread, and I have read other information about using WVO. I have never read anything about the "actual" miles/gallon with WVO. Since you are in the planning stage, you have no personal knowledge of the MPG of WVO, but you probably have heard what others claim. Would you please share that information? Thanks, Sam Sperbeck La Crescent, MN |
Deacon (204.184.224.4)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 9:41 pm: | |
There is a yahoo groupjust for busnuts to exchange information on useing SVO or WVO. http://autos.groups.yahoo.com/group/wvobus/ Personally I intend to add a 150 gallon WVO heated tank in the rear bay of the 4106. At 8 to 9 MPG this will give me a range of a thousand miles at a cost of .25 to .30 cents per gallon versus 2.00 a gallon for dino diesel. New SVO can be purchased at almost any resturant supply company under 2.00 per gallon so at todays prices for diesel its still cheaper. Several motorhomes are already running on WVO without problems. There is a Mack semi on the greasel website that I contacted the owner. He now has over 100,000 running on WVO without any major problems. The power and milage are the same as the dino diesel, the emmisions are far, far less. No internal modifications are done to the motor. Your diesel genset can also be run on WVO. John 4104 & 4106 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 9:56 pm: | |
Very true John, my only question is why so many people are so pig headed. I have converted a VW golf engine which has been running and show no abnormal wear (it had 150k on it to begin with) and in my business - I own Christopher Goodwin Motorsport, a shop in Seattle specializing in German car repair and restoration - I have occation to work on several Bio-diesel vehicles, both Mercedes and VW. I chose to avoid Bio-diesel as I do not want to spend my travel time doing chemistry in a McDonalds parking lot. Please contact me regarding your conversion at 206-227-7355 or by email at cg@goodwinmotorsport.com Cheers, Chris |
john marbury (Jmarbury) (66.82.9.24)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, May 27, 2004 - 11:14 pm: | |
The 2 stroke requires that the fuel be returned to the tank, thereby cooled down before it is sent back to the injectors. How have you addressed the return and cooling of the greasel? John |
Phil Dumpster (24.16.243.37)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 12:08 am: | |
"Very true John, my only question is why so many people are so pig headed. I have converted a VW golf engine which has been running and show no abnormal wear" Your Volkswagen diesel engine and a DD 6V92TA have about as much in common as an apple has with a tomato. Both are red, both are fruits, both have seeds, but the similarities end there. I have yet to see a documented case where someone ran a Series 92 on waste vegetable oil for a significant amount of use without harming the engine. |
Adame (129.82.53.100)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 12:56 am: | |
Question for Phil Dumpster: Have you seen a documented case of a series 92 which was damaged by the use of vegetable oil? |
Derek (24.85.245.203)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 3:39 am: | |
Which one costs more? Finding out the engine runs on WVO or finding out the engine doesn't run on WVO? Of course theory is good, but I, like others, would be seriously concerned about the cooling of the injectors if the fuel being put through them is 170F to begin with. Not saying it cannot be done, but I would be extremely cautious about it... One other thing, Biodiesel and WVO concepts have been around since what, the early '80s? Why hasn't it caught on yet? I have yet to see any documented proof of a VW Rabbit or Jetta, or Golf running the 400,000km (sorry, Canadian here) or more that can be expected out of a dino-diesel engine. |
cgoodwin (208.12.28.149)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 10:09 am: | |
Henry B, I just read your post, must have skipped over it or my mind simply blocked it out due to it's lack of LOGIC. "It does not matter where the stored carbon comes from...either from tiny vegetable forms layed down..millions of years ago as coal or oil, or from the carbon taken up from the plants today...that are "recycled" as vege oil, carbon in the atmosphere is carbon in the atmosphere." Perhaps a little history refresher would make it clear: Long, long ago the atmosphere was much different than today (skip ahead) micro-organisims began to break down the gasses in the atmosphere and minerals in what was then the sea (skip ahead again) as these organisims died and settled they took the carbon with them and formed large deposits which form the oil we use today. Now if you can not see the difference between re-introducing that carbon back into the atmosphere and using carbon which is present in the current gas-plant exchange then think of it this way, one way adds carbon to the current atmosphere, the otehr does not. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 10:12 am: | |
Back in the '80s we burned waste oil in the dryer of the blacktop plant I ran. We heated that oil to 140 degrees to burn it, why isn't anyone promoting the use of it in their diesel engine? I imagine that would be readily available around the country at low cost or free, too. Also, back in the '80s, there was a lot of experimenting with pure alcohol in gas engines, where did that research lead? I am certainly not opposed to new ideas, I'm just too timid to try them without a lot of information to support their practically. Thanks, Sam Sperbeck La Crescent, MN PS for Chris, my '74 MB 240D has a problem with the fuel running back and causing hard starting. When I take the cover off the fuel filter, after the car sits a long time, the fuel level is down to the pipe near the bottom. Is there a check valve between that pipe and wherever that line leads? Thanks |
James Maxwell (Jmaxwell) (66.81.211.188)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 10:45 am: | |
Consider this. How many meals would you collect from all that sediment that u filter out of this WVO on an 8-10k mi. trip across the country and back? At 7mpg and 8k mi. probably at least a dozen portions of large fries there in that 1100+ gallons! Just saved $25 on food also. Sorry Derek, but I have to disagree. In this case, not even the theory is good. This WVO thing is like travelling in Mexico 20 yrs. ago---you would spend most of your time hunting fuel and then hoping that the engine would run on it after u got it. All this effort just to go on vacation? Hell, if u want a job u may as well get one that pays. |
WVO Wannabe (68.243.214.31)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 11:14 am: | |
There is a guy that I met that had a Eagle that had converted his system. This guy had at that time approx 16k miles running WVO. He claimed he never had any problems with the system. He did however do a double filtration on the wvo prior to adding to vehicle then had I believe three ricors in place. I am not positive on engine size but I think it was the 318 detroit. He introduced me to www.greasecar.com. This introduction was nearly 16 mos ago. |
Gary Carter (68.25.50.92)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 12:23 pm: | |
I see nothing wrong with running WVO except if we all decide to do it and then there will be a severe shortage. There just is not enough of it to make it a viable solution for the masses. Same with achohol. Even with the massive plant being built to produce achohol for cars there still is not enough. Often there is a gas shortage because they can not get the achohol needed. All these systems look good for onezy-twozys but lose out when you look at the volume needed for the masses. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 2:21 pm: | |
Sam - There is a one way valve at the base of the primer pump, remove the primer pump - not easy the first time - and replacee the valve. Check it by unscrewing the pump and work it, if it pumps out the bottom, it is bad and needs to be replaced. I believe the repair procedure for a 1974 240D reads; Remove fuel cap, replace vehicle, reinstall fuel cap. Just kidding, not a bad car but the 0-60 time is about 6 minutes ;-) Chris |
CoryDane RTSII (66.155.188.188)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 4:29 pm: | |
Alrighty then.... Sam said "Also, back in the '80s, there was a lot of experimenting with pure alcohol in gas engines, where did that research lead? I am certainly not opposed to new ideas, I'm just too timid to try them without a lot of information to support their practically" I was reading about the future in the past, when they were just beginning to make cars with engines. The big discussion was what fuel to burn. The first cars, according to the article, burnt ALCOHOL to run down the (not yet) roads of America. When Oil was found and it was cheaper to make gasoline than it was to make Alcohol, they shifted gears and fueled the cars with Gasoline. The technology for Alcohol burners is in the archives of the auto manufacturers. I would think, if it did'nt show up back in the 70's when we had the energy crisis, then there must be a reason that it was not brought back to existance in the transportation market. There is a guy, was on the news, says he has a product, made from frying oil, that can be put in the fuel tank with no changes to the vehicle and will run as well as diesel. He is patenting his process and trying to build stations to sell his diesel replacement. This, we will have to see. "Imagine" cd |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 5:16 pm: | |
Hello cgoodwin; Thanks for the clarification regarding my post about the carbon uptake in todays atmosphere from fossil fuels vs current farm vege oil. I think we are talking about the same thing, only the perspective and time line is different. I refere to carbon uptake regardless of source. Your arguement makes the distinction between old carbon and new carbon. Thank you. We possibly agree vege oil may hold promise. My/your/our VW Rabbit diesels do have a rather primitive fuel injection system with a very low injection pressure. My owners manual says the... ...mill can run in an emergency on all sorts of different oils, including, but not limited to... drain oil, diesel oil, fuel oil, a small... ...percentage of gasoline or kerosene, plus possibly vege oil. I did see a couple of years ago an older 743 Cummins diesel(?) Gillig... ...bus that had a sign proclaiming that it was running on reclaimed McDonalds vege oil. Seemed to go fine with no smoke...but as I recall... ...the exhaust smelled like onion rings. He he he. Getting back to your planned application, I wonder if the energy required to grow the... ...corn in the first place; (western farming techinques are VERY energy or fuel intensive) would offset any possible savings to the ... ...environment in comparision to just using fossil fuels in the first place. We need to determine an accurate equation showing... ...that reclaimed vege fuel has a viable chance of replacing some of the diesel now used. Right now my guess is that it is still cheaper... ...AND cleaner to just continue to use fossil fuels. This is because of the tremeduous consumption of fossil fuels to grow the... ...crops to feed us overweight Americans. Now if we can come with a scheme that uses Chinese farming methods to grow the corn, then using... ...vege oil may work out. Anyway, I am babbling, something that happens frequently nowadays. Thanks for your post. |
Deacon (150.199.209.48)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 5:28 pm: | |
..."There is a guy, was on the news, says he has a product, made from frying oil, that can be put in the fuel tank with no changes to the vehicle and will run as well as diesel. He is patenting his process and trying to build stations to sell his diesel replacement. This, we will have to see." ... "His" process may be patentable, but, there are many processes already being used that you can do at home with very little cost to you. As far as supplies while on the road, there are now several small compact filter units being made and soon to be more efficient units as the incentive grows due to higher and higher fuel cost. Be practical, just how many gallons do you use yearly? How many trips over a thousand miles round trip? Lets say you use around 120 gallons for a weekend trip, at 2.00 per gallon (don't you wish California) thats $240, at >30 cents per gallon for filtering WVO thats $36, a savings of $204! Thats just one holiday weekend trip. Now WVO weighs less than water (oil floats on water) I took a sample and it weighed 7.7 pounds un-filtered. Smaller fresh and black water tanks leave room in the rear bay for 150 gallon of WVO. Another tank under the bed above can store another 100 gallon to refill my heated tank as needed by opening a valve, easy and simple! Now I have around 230 gallon of WVO useable, or, aprox. 1850 miles without refill at a cost of $69, if that don't excite you than nothing will. http://autos.groups.yahoo.com/group/wvobus/ and check the files section for good information sites. PS...the question was posed above, can you document any engine that has been damaged by useing SVO/WVO? John 4104 & 4106 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, May 28, 2004 - 10:29 pm: | |
Hi Chris, Your repair procedure for my 240D is probably true if I were to take it to a shop to have the work done. This is still a very nice car with only 305,000 miles on it so I would like to keep it running a while longer. It certainly doesn't set any acceleration records but it is a good steady car that gets good fuel economy. I have had it since 1980 so it's sort of part of the family and I still enjoy driving it. Thanks for the information. Sam |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 30, 2004 - 5:10 am: | |
Adame wrote "Question for Phil Dumpster: Have you seen a documented case of a series 92 which was damaged by the use of vegetable oil? " No, but I'm not going to be the one to make the documented report and then pay several thousand dollars to have my Series 92 engine repaired after the experiment. The DD mechanics I have talked to doubt waste vegetable oil would work in the 2 cycle engines for a number of reasons, the main one being that these engines use the fuel to cool the injectors. Preheat the fuel, and you defeat the injector cooling. Now, I don't know how running the injectors hotter than normal would affect their life, but I'm not going to be the one to find out. Another point - the 2 cycle Detroits are direct injection engines. A number of the reports I have seen regarding waste vegetable oil performance in direct injection engines is that it doesn't work too well. Engine operation tends to be rough at idle and combustion isn't very clean. Indirect injection engines (using a prechamber) seem to work on vegetable oil quite well. The prechambers seem to aid the initial combustion upon injection. By all means, if you have a bus with a 2 cycle Detroit engine, run it on vegetable oil and let us know how things turn out. I won't take that kind of chance with mine. |
Stephen Fessenden (Sffess) (65.129.241.239)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 30, 2004 - 5:19 am: | |
Sam, I have a rebuilt 240D late model engine to sell. I bought it to convert a UNIMOG 404 to diesel but abandoned the porject. Engine is only $1000. Iterested? I am in Florida. sffess@quixnet.net Try changing your fuel lines between injectors and the one to the filter from the injectors and the end plug on the last injector. If any air can get into these lines, the fuel prime will be lost over time sitting. |
Johnny (68.0.241.248)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 30, 2004 - 7:52 pm: | |
I want to do this with my F-350 & my wife's Blazer...it beats $2/gallon. |
niles (4.4.112.82)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 12:28 am: | |
??? How would you deal with the WVO remaining in the supply line between use? wouldn't you have to preheat the lines to avoid clogged arteries? |
Dale MC8 (69.19.175.99)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 1:04 am: | |
niles, idealy you would switch over to diesel about 10 min before reaching your destination to purge the lines of WVO. |
Peter Broadribb (Madbrit) (67.136.116.215)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 4:21 am: | |
But if for some reason you can't flush it through with #2, such as a sudden mechanical failure, burst water hose, etc you're in the deep sticky goo for sure. No thanks, I'll keep pumping my #2 and keep my very expensive engine in the best condition I can. I really cannot understand this use of dirty cooking oil. You guys with the 2 strokes make such a big deal over running exactly the right engine oil, but you "Greasel" supporters will risk clogging up its arteries from one end of a 40ft bus to the other. You have no idea what has been dumped in those waste tanks along with the oil. Btw, what do you do with the residue from the filtering process? All that sticky smelly goop has to be dealt with according to the EPA rules. Peter. |
Scott Whitney (66.82.9.79)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 10:35 am: | |
>>>All that sticky smelly goop has to be dealt with according to the EPA rules. Campfire & BBQ starter? Roast your hotdogs over it and you don't need the chips as a side dish. Or maybe could be sold at bus rallies as Aluminum Siding and Alcoa Rim Polish. . . Scott |
Deacon (150.199.209.33)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 1:57 pm: | |
niles, the WVO supply line is wraped together with the coolant lines that heat the WVO tank. The supply line will heat befor the tank is heated. The solonoid to switch from diesel to WVO is located close to the motor fuel pump so the flush time is 5 minutes or less. BTW: there are no EPA regs to worry about, WVO is considered a food and can be disposed of as you would a half eaten burger. http://autos.groups.yahoo.com/group/wvobus/ |
Peter Broadribb (Madbrit) (67.136.93.200)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 2:20 pm: | |
Maybe you can dispose of it where you like, but don't dump it in the trash can, it would soak through the paper bag the burger came in. I read there was a problem with hot fuel and therefore not cooling the injectors on 2 stroke diesels, maybe 4 strokes too?? Nah, sorry, you can keep the "Greasel", my motor is too valuable to mess with and all that smelly goop too, slopping about in the bays, yukk!!! Just my opinion, but don't park next to me if it's at all smelly, thank you. Peter. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 3:07 pm: | |
Peter, no one is trying to talk you into doing anything! Your opinion has been well stated. As soon as the Tech's answer my question about allowable injector and fuel temps I will be glade to post it, pro or con. Until then, if someone has information other than "I heard" or "my mechanic said" please post the source, I would like to know too. So far everyone that is acually 'doing it' has stated no problems and some have over 100,000 miles. |
Johnny (4.174.112.42)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, June 02, 2004 - 8:10 pm: | |
Smelly? Yes--it smells like whatever was cooked in it. |
Dale MC8 (69.19.169.205)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, June 03, 2004 - 6:23 pm: | |
FYI, the 1st Sunday of the month @ 11 am, Real Goods in Hopland CA conducts free classes on Making Your Own Biodiesel with the FuelMeister (suprise, they also sell the FM.) Call (707) 744-2100 to sign up. They are located at 13771 Hwy 101 in Hopland. They also have a website. I have no connection to these people except as an occasional customer. HTH Dale |
